Etabs design
Elakkiyarajan
PostPosted: Sun Jul 14, 2019 4:22 pm    Post subject: Etabs design Reply with quote
Respected Sefians
In etabs column design, after analysing and concrete design it shows some longitudinal reinforcement value. If I change frame type from "ductile"to"ordinary". Longitudinal reinforcement values may change drastically. Is it right procedure to change like that.  Please sefians through some light on it.
And I use etabs 16 and etabs 17. Both shows different reinforcement values for same model. Which version is preferable.
Rifat Bin Ahmed
PostPosted: Sun Jul 21, 2019 8:55 am    Post subject: Re: Etabs design Reply with quote
How can you change frame type in ETBAS 16?As far I know there are no procedure to change ductile to ordinary frame.Do you change Sway special to ordinary frame in etabs?
sakumar79
PostPosted: Tue Jul 23, 2019 10:53 am    Post subject: Reply with quote
Dear Er Elakkiaraj,
    ETABS uses IS13920 to design members when Ductile design parameter is used (under View/Revise overwrites). This is the default for any member created in a model even after all existing members have changed the parameter. If you are designing the structure to IS13920, you should use Ductile parameter, else you should change it to Ordinary.
    If you are getting different values of steel in 2016 and 2017 versions, please check the member end forces. If these itself are different, there is a change in analysis results. If these are same, design alone is different. You can try to compare with hand calculations to see where the difference is.
   You can also go through the changelog to see if there was revision in the analysis or design aspects. This will help identify if the change was deliberate or accidental.
   For further guidance, you should contact the ETABS customer support.
Hope this helps
S Arunkumar
Maulik Hothi
PostPosted: Thu Jul 25, 2019 5:08 am    Post subject: Re: Etabs design Reply with quote
Respected Sefians
Dear Er Elakkiaraj,
If you Change the Column design, after analysis and concrete design "ductile"to"ordinary" etabs skip the ductile detailing code.
Etabs 2016 is not updated with IS code 13920 2016 and Etabs 17 is updated with IS Code 13920 2016
IS code 13920 2016 introduce Relative strength of beam and column at a joint clause no. 7.2 P.N. 8
In ductile case Etabs Model use IS 13920 2016 clause no. 7.2 for ductile details and In ordinary case Etabs model skip the IS 13920 2016 code.
I hope you get the answer
Maulik Hothi
Elakkiyarajan
PostPosted: Fri Jul 26, 2019 5:24 am    Post subject: Reply with quote
Dear sefians
Thanks all for clearing my doubts regarding in etabs
