Single stair steel stringer beam at centre
sarif.muhammed
PostPosted: Sun Jul 21, 2019 4:31 am    Post subject: Single stair steel stringer beam at centre Reply with quote
What are the precautions or checks we need to do in order to design a steel stair case with steel stringer beam at center as shown in images,
Does I section is a viable solution for this?
Sarif
 Filesize:  126.75 KB
 Viewed:  51 Time(s)
 Filesize:  64.63 KB
 Viewed:  48 Time(s)
sakumar79
PostPosted: Tue Jul 23, 2019 10:57 am    Post subject: Reply with quote
Dear Er Sarif,
   In addition to typical design for DL+LL, the stringer beam has to be designed for DL+Half LL assuming the half LL is fully on one side of the beam. This will result in UDT on the girder and hence ISMB sections may not be most suitable. Rectangular Tubes, Double ISMC as Box sections or a tube built up with plates may be more economical.
Hope that helps
S Arunkumar
dgupta
PostPosted: Fri Jul 26, 2019 10:11 am    Post subject: Reply with quote
You may want to check for vibration as well.
abhio
PostPosted: Fri Sep 06, 2019 1:41 pm    Post subject: Reply with quote
Please also consider lateral load on the handrail as per IS: 875 (Part - II).
The toughened glass/ acrylic balustrade is interesting. I suppose it requires very strict deflection control to prevent cracking.
