Flanged Cruciform Sections
ratnakishorerk
PostPosted: Sun Jul 21, 2019 3:42 pm    Post subject: Flanged Cruciform Sections Reply with quote
I am masters student working on Power plant Design where I found most of the columns used there were Flanged Cruciform I sections.
Can anyone please eludicate about these Flanged Cruciform Sections?
What is the major advantage of using Flanged Cruciform Sections (Plus Sections ) over Box Sections???
With Regards
V.V. Ratna Kishore
M.SED
CEPT University
Ahmedabad
Rudra Nevatia
PostPosted: Mon Jul 22, 2019 2:39 pm    Post subject: Reply with quote
Hi Ratna Kishore,
Flanged cruciform sections are used for providing moment resisting frames in orthogonal directions.
A better option is to use I sections for moment resisting frames in one direction and braced frames in the perpendicular direction.
Rudra Nevatia
PostPosted: Tue Jul 23, 2019 3:09 am    Post subject: Reply with quote
I hope, for equal weight of the section, box sections will be more efficient as compression members compared to flanged cruciform sections, as the latter can be susceptible to torsional buckling.
ratnakishorerk
PostPosted: Tue Jul 23, 2019 7:05 am    Post subject: Reply with quote
Rudra Nevatia wrote:
Hi Ratna Kishore,
Rudra Nevatia
Respected Mr.Rudra Nevatia ,
Thank you for your  reply!
I just wanted to know more about these sections ! I gone through the internet and referred some papers but I did'nt got the actual design or bahaviour regarding those sections of my level .Can I get any structural behaviour / design references of those cruciform sections if available!
With Regards
V.V.Ratna Kishore
M.SED
CEPT University
ratnakishorerk
PostPosted: Tue Jul 23, 2019 7:35 am    Post subject: Reply with quote
Respected Mr. E S Jayakumar
Yes the same thing I also intended to say then for seeking  the advantage of flanged cruciform sections over box sections!
Also I think the flanged cruciforms will be having greater structural properties compared to plain cruciforms.
Here I am attaching the experimental research paper which will give us a keen idea about that!!
Also If possible I request you to suggest any references regarding design and structural behaviour of these type of sections!!
Please correct me if I went wrong anywhere!
Strength Comparision of Flanged & Plain Cruciform Sections.pdf
Structural properties compartive study between Plain and flanged cruciforms.
 Filename:  Strength Comparision of Flanged & Plain Cruciform Sections.pdf
 Filesize:  1.45 MB
 Downloaded:  140 Time(s)
PostPosted: Tue Jul 23, 2019 2:31 pm    Post subject: Reply with quote
Er. Kishore,
You said :
"Also I think the flanged cruciforms will be having greater structural properties compared to plain cruciforms"
Yes, by virtue of increased distribution of mass (in flanges) away from the neutral axes, which boosts the moment of inertia.
I hope you can design this section as compression member using the properties of buckling class-C, like any other built-up sections.
shashin
PostPosted: Thu Aug 29, 2019 12:31 pm    Post subject: Reply with quote
Dear Ratnakishor,
As rightly said by Mr. E S Jayakumar, it can be designed as buckling Class 'C'.
Further,  some of the practical advantages of Flanged Cruciform section over other sections (though BOX section has higher LTB resistance than this) like:
1) It has greater Moment of Inertia in both the direction than sing I section
2) Generally, Bolted connection is preferred at site.It is very easy to use Cruciform section for bolted connection at site and bolting can be done directly with flanges in all direction (The same is difficult for BOX section and separate connection plate required to do bolting in BOX section, and connection goes outside the section size )
3) Base Plate section is reduced as you can provide Anchor bolts neared to center between "+" flanges (In Box section, all bolts need to have outside the section, requires larger size of base plate and accordingly, Pedestals)
Shashin
