Gems of Structural Engg - Dr N Subramanian - (Post-27)
Goto page 1, 2, 3, 4, 5  Next
abhy_vivek
PostPosted: Mon Nov 15, 2010 9:55 am    Post subject: Gems of Structural Engg - Dr N Subramanian - (Post-27) Reply with quote
Dr N. Subramanian
Dr. N. Subramanian, is a Civil / structural consultant (currently based at Maryland, USA) with over 30 years of experience in Industry (including consultancy, research and teaching); former CEO of Computer Design Consultants, India, and Director of Computer Technological Institute, author of 200 technical papers and 25 books, is an asset for the field of structural engineering.
Academic :
Dr. Subramanian, born at Srivilliputhur, Tamilnadu, and brought up in Chennai, did his initial schooling in Chennai. Later he joined Thiagarajar college of Engineering, Madurai for perusing his graduation in Civil Engineering. After graduation, he soon completed his Post Graduation in Structural Engineering from College of Engineering, Guindy, Chennai and then joined IIT-Madras (now Chennai), for doctoral degree. He did his Ph.D. under the guidance of Professor Prof. C. Ganapathy and topic for the research was “Analysis and behavior of steel frame folded plate roofs”. Then he was with IITM, as Post-doctoral Fellow & Project Associate for about two years. He also worked with Technical University of Berlin (with Prof. J. Lindner) and the Technical University of Bundeswehr, Munich (with Prof. Ch. Petersen) for two years as an Alexander von Humboldt Fellow.
Professional Experience :
After completing academic studies, Dr. Subramanian engaged himself in actual practice. After working for a brief period with College of Engineering, Guindy as Asst. Professor, he started his own consultancy in the year 1982. Consultant to several organizations like TANSI, Indian Telephone Industries Ltd, GTL Limited, Tamilnadu Housing Board, Hutch Limited, Tube Investment in India, E.C.C (I) Ltd. , Airtel Limited, Thapar waterbase Ltd. , T & B International Ltd., Riyadh; and AB Wibe , Sweden, his organization has executed the design of more than 650 projects, including several multi-storey concrete/steel buildings,  Communication and microwave towers (designed more than 500 towers ranging in height from 20m to 120m), Pile and Tower foundations, Space frames, Sugar plant and aqua culture plants, Industrial structures (using hot rolled and cold rolled steel sections), schools, hotels, hospitals and some special structures. Dr. Subramanian also developed 18 special purpose software packages for the analysis and design of structures using FORTRAN and C, and used by more than 120 organizations in India.
He was holding a CEO position for Computer Design Consultants, <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" /><st1:country-region w:st="on"><st1:place w:st="on">India</st1:place></st1:country-region>. During the long journey of 30 years, he invested his valuable time in making next generation of civil / structural engineers, contributing to technical forums and also in research works.
Based his excellent work he also received several awards including the Tamil Nadu Scientist Award, and the ACCE – Nagadi award for best publication for his book, Principles of Space Structures. He is registered as Professional Engineer, Institution of Engineers, India, and Registered Valuer of Income Tax Dept., Govt. of India.
Literature :
Dr. Subramanian, wrote and published more than 200 Technical papers in national and International Journals, on various aspects of Civil / Structural engineering including behaviors of concrete and steel structures.
These papers include popular once like -
Aesthetic Appraisal to Antenna Towers, Journal of Architectural Engineering, ASCE,
*Restoration of a Cold Storage Factory Building, Journal of Performance of Constructed Facilities, ASCE.
* Steel Dome of Jawaharlal Nehru Indoor Stadium, Int. Journal of Space Structures
* Traglastversuche an zweifeldtragern  mit  dunnwandigen C-Profilen, Der Stahlbau
* Tragverhalten Stahlerner Fachwerktonnen, Der Stahlbau,
* Prefabricated steel frame folded plate roofs, Bulletin of IASS,
* Computer Analysis of Space Frames with Offset Members, Int. Journal of Computers and Structures,
* A space frame roof for industrial buildings, The Bridge and Structural Engineer
* Optimal Frame design using non-linear programming, The Bridge and Structural Engineer
* Recent Progress in the Field of Lateral Instability of Steel Beams, The Bridge and Structural Engineer
* Design of : AntennaType Towers, The Bridge and Structural Engineer,
* Design   of   Tower Foundations, ICJ
* Design of under reamed Piles, ICI Bulletin
* Concrete Cover for durable RC structures, ICJ,
* Recent Developments in the Design of Anchor Bolts, ICJ
* Seismic Design of Joints in R.C. Structures – A Review, ICJ
* Sustainability-Challenges and Solutions, ICJ
* Curing- The Last and the Least Considered Aspect in Concrete Making, ICI Journal
* Fees for Structural Consultants,
* Pervious Concrete-A green Material that helps reduce water run-off and Pollution, ICJ
* ‘Limiting reinforcement ratios for RC Flexural members’, ICJ
* Corrosion protection of steel structures, The Master Builder,
* Pre-qualified Seismic Moment Connections, NBM & CW
In addition to various papers, Dr. Subramanian has composed 25 books, amongst them are the two books on Steel Structures (limit state method) published by Oxford University Press, New Delhi and another on Space Structures (First two editions published by Wheeler publishing & the latest one by Multi-Science, U.K.) are very popular amongst the fraternity. The other books are on programming and computers. He also published a book on Jokes!
Contributions to the Society :
Dr. N. Subramanian in a Life Fellow/Member of various national and international institutions, including ASCE, ACI, ICI, ACCE (India), IEI (India), and Computer Society of India. He delivered lectures in many seminars and courses. He served/serving as Editorial/Review committee of the following: Bulletin/Journal of the Indian Concrete Institute, CE &CR, Int. Journal of Space Structures, U.K.; Indian Concrete Journal Applied Mechanics Reviews, U.S.A. & American Concrete Institute.
He has Served as Vice President of the Indian Concrete Institute and Association of Consulting Civil Engineers (<st1:country-region w:st="on"><st1:place w:st="on">India</st1:place></st1:country-region>).  He also acted as external examiner for M.E., M.S., & Ph.D. Thesis.
He organized several seminars/conferences and edited their proceedings.  He also was an Organizing Committee member of several seminars/workshops. He has also reviewed several books for journals and wrote articles in Newspapers. Dr. Subramanian has instituted an Award through the Association of Consulting Civil Engineers, for best software in Civil Engg. He also was also an active Rotarian and served his club in various capacities, including the post of President.
Dr. Subramanian is an active and sponsor member of Structural Engineering forum of India. He keeps motivating and sharing his experience with the growing structural engineers on the forum.
For more info: Visit www.cdcstruct.com
We are thankful to Dr. Subramanian for his contribution to the field and also wish him all the best for his future endeavors.
Vivek Abhyankar - C.Eng
MACI, MICI, MINSDAG, MISSE, MIIBE, MASTR
Structural Engineer
Mumbai
Thankful People
sukanta.adhikari
PostPosted: Mon Nov 15, 2010 11:02 am    Post subject: Re: Gems of Structural Engg - Dr N Subramanian - (Post-27) Reply with quote
I am very happy to see this post.
Many times we have seen this topic been discussed "Gems of structural Engineering"..
in which we have seen lot of gems of structural engineering..but we forget our own gem of the forum,ie, Dr N Subramaniam.I thank Vivekji for this post.
Dr Subramaniam is a  good academic person , Practical engineer and above all a very good human being.
Actually I was also working on same subject..But vivekji posted before me..
S.Adhikari
abhy_vivek wrote:
Dr N. Subramanian
Academic :
Literature :
Structural Engineer
Mumbai
abhy_vivek
PostPosted: Sun Jul 22, 2012 3:44 pm    Post subject: Re: Gems of Structural Engg - Dr N Subramanian - (Post-27) Reply with quote
     Resp. Dr. Subramanian Narayanan's Brief engineering biography First published in The Indian Concrete Journal, May 2012, Vol. 86, No. 5, pp. 37-38.
Reg
Vivek
Structural Engineer
Mumbai
[/quote]
Biography Dr. N. Subramanian-ICJ-May 2012.pdf
Biography of the Gem
 Filename:  Biography Dr. N. Subramanian-ICJ-May 2012.pdf
 Filesize:  761.29 KB
 Downloaded:  912 Time(s)
PostPosted: Mon Jul 23, 2012 5:26 am    Post subject: Gems of Structural Engg - Dr N Subramanian - (Post-27) Reply with quote
We must thank Er Vivek for including this much awaited Biography of Dr N Subramanian sir ,
a living legend of structural Engg and our Top sefian in the Gems of Structural Engineering
section.
It is his sound knowledge together with sense of sharing and wholeheartedness which
distinguish him from other Gems.
Apart from his 200 papers and 25 Books , he has spent hours for SEFI with over 3500 posts
to resolve problems faced by engineers ,especially structural Ers, on a daily basis since
last 8-9 years here on sefi - - - a mega contribution to fraternity.
- - - - - -Certainly GOD gifted attitude for sharing
with appreciation and regards
vikramjeet
Dear Sefians, Resp. Dr. Subramanian Narayanan's Brief engineering biography First published in The Indian Concrete Journal, May 2012, Vol. 86, No. 5, pp. 37-38. Reg Vivek
PostPosted: Wed Jul 25, 2012 8:38 pm    Post subject: Re: Gems of Structural Engg - Dr N Subramanian - (Post-27) Reply with quote
Dear Er Vikramjeet,
Thank you for your kind words.
I hasten to state that your contribution on a daily basis, with more tinge towards practical aspects, is in no way inferior to my contribution. I always used to wonder how you are finding time to answer so many questions, considering the fact that you do not have internet facility at home.
May God Bless you and another Gem of SEFI Er Rangarajan!
I take this opportunity to thank Er Vivek for posting my profile here and Er. S.Adhikari for his kind words.
Regards & Best wishes,
section.
vikramjeet
abhy_vivek
PostPosted: Wed Nov 06, 2013 8:18 am    Post subject: Re: Gems of Structural Engg - Dr N Subramanian - (Post-27) Reply with quote
ICI - L & T Award for Life Time Achievement 2013
      I am happy to share here that Dr. N. Subramanian ji, has received the ICI - L & T Award for Life Time Achievement 2013, for his contributions to the field of 'Design of Concrete Structures', during the AGM and Award function conducted during the ICI-IWC 2013- International Conference on Innovations in Concrete for meeting Infrastructure Challenge, held at Hitex Exhibition Centre/NAC, Izzat Nagar Hyderabad 500 084, on Oct. 25, 2013.
(Enclosed a few photos taken during the function)
Let's join together to congratulate Dr. N. Subramanian sir on this achievement . . .
 Filesize:  407.61 KB
 Viewed:  1600 Time(s)
 Filesize:  54.59 KB
 Viewed:  1599 Time(s)
 Filesize:  407.57 KB
 Viewed:  1641 Time(s)
VPandya
PostPosted: Wed Nov 06, 2013 12:40 pm    Post subject: Many thanks for posting achievements of Dr. N. Subramanian. Reply with quote
Dear  Er.  Abhy_Vivek,
I add my thanks to you for posting  details about achievements  of  Dr. Subramanian in the field of Structural Engineering . In a way I am also his student (who is not among 14000 Sefian's?) because I use his Steel Design book " Design  Of  Steel Structures " .
Vasudeo Pandya P.E. ; S.E.
Structural Engineer
PostPosted: Wed Nov 06, 2013 5:53 pm    Post subject: Re: Many thanks for posting achievements of Dr. N. Subramani Reply with quote
Dear Er. Vivek and Er Pandya,
Many thanks for your kind words. May God Bless You!
Structural Engineer
prof.arc
PostPosted: Thu Nov 07, 2013 10:59 pm    Post subject: Re: Gems of Structural Engg - Dr N Subramanian - (Post-27) Reply with quote
Dear Dr. NS,
hearty congrats for one of the numerous awards that you got and will be getting
in future.
May GOD always Bless you
sincerely
ARC
mtamil
PostPosted: Fri Nov 08, 2013 4:43 am    Post subject: Re: Gems of Structural Engg - Dr N Subramanian - (Post-27) Reply with quote
Dear NS sir,
வாழ்த்த வயதில்லை, வணங்குகிறேன்.
Tamilarasan
PS: Non-Tamils pl excuse.
Page 1 of 5
