P and V values to be taken while defining auto hinge for pushover analysis in etabs, sap2000
BivekSigdel
PostPosted: Thu Aug 15, 2019 2:24 am    Post subject: P and V values to be taken while defining auto hinge for pushover analysis in etabs, sap2000 Reply with quote
Dear all,
I've searched a lot, but still couldn't get an idea what is the appropriate loading case or combination to get the values of P and V while defining auto hinge for pushover analysis in etabs or sap2000.  P and V values are required as per the table 10-7, 10-8 of ASCE 41-13, table 6-7, 6-8 of FEMA 356 and table 11-3, 11-4 of ATC 40.
For each column the P value can be maximum due to different load combinations. So does it mean that I have to know which combination gives max. P in each column and assign different auto hinge for each column? Also the case/combination for maximum value of V can be different from P. In this case how can we assign only one load case/combination for both P and V values.
For beams, maximum V values result from the ductility requirements due to sway and hinge formation in beams and not from load cases/combinations.
I would really be grateful if somebody could give me an insight to which load case/combination is appropriate of P and V values while defining auto hinge for pushover analysis in etabs or sap2000.
Please see the picture attached.
Thankyou,
 Filesize:  28.55 KB
 Viewed:  43 Time(s)
 Filesize:  28.08 KB
 Viewed:  41 Time(s)
