A New idea for RCC COLUMN design
Goto page Previous  1, 2
aslam
PostPosted: Thu Sep 05, 2019 7:00 am    Post subject: Design of RC column Reply with quote
Congratulations for your great effort.
The sheet works fine. However I think the Ast you get is comparatively higher.
Fck= 20 N/MM2 8.888889
Fy= 415 N/MM2
P= 1000 KN 500
Mx= 230 KNM 230 *less than min eccentricity*
My= 230 KNM 230 *less than  min eccentricity*
Bx= 500 MM
Dy= 500 MM
As= 8631.004 MM2
ex= 230 230 25
ey= 230 230 25
A1= 250000
A2= 921600
As1= 0
As2= 8631.004
8631.004
compare (2).pdf
 Filename:  compare (2).pdf
 Filesize:  269.79 KB
 Downloaded:  302 Time(s)
mohd_arastu
PostPosted: Thu Sep 05, 2019 7:30 am    Post subject: A New idea for RCC COLUMN design Reply with quote
Hi,  can you please share the excel file?
On Thu, Sep 5, 2019, 9:54 AM rg.gupta <forum@sefindia.org (forum@sefindia.org)> wrote:
           Dear Manoharbs
Jai Hind
    It is advised in future pl do not  make any comment  in haste ,before you make a proper  study of the case in  depth & get the feed back.
Now it is suggested to go through the results of some of the solved examples of SP-16 of BIS ,Author A.K.Jain & Authors Karve & Shah Books on RCC
and comparison with My program results as given  below:
 1) SP-16 of 1980
                          a) Exp. 5 on page 99
                          b) Exp. 6 on page 103
                          c) Exp. 7 on page 103
                          d) Exp. 8 on page 105
                          e) Exp. 9 on page 107
2) A.K JAIN
                           a) Exp. 16.8  on page 493
                           b) Exp. 16.9  on page 495
                           c) Exp. 16.10 on page 496
3) KARVE & SHAH
                           a) Exp.  4-1 on page    787
                           b) Exp.  9.6-1 on page 878
                           c) Exp   9.6-2 on page 879
                           d) Exp.  9.6-3 on page 881
                           e) Exp.  9.6-4 on page 882
                           f) Exp.   9.7-1 on page 885
As there are so many softwares available here such as strap1,staad & Etab etc ,the results obtained from them are at variance also with consultant to consultant.
It is further clarified that this concept /research is at a very initial stage, may invite some minor modifications such as effective cover etc. are underway
which will have minor impact even now the results obtained are comparable with any body's as  these results are  based on basic fundamentals are  perfect
& genuine .
R G GUPTA S.E(Retd.)
CDO/DDA
rg.gupta41@gmail.com (rg.gupta41@gmail.com) (rg.gupta41@gmail.com (rg.gupta41@gmail.com))
9718829191
N. Prabhakar
PostPosted: Thu Sep 05, 2019 1:13 pm    Post subject: Reply with quote
Dear Er R G Gupta.
I have one doubt.  The examples shown in your Excel sheets consider only short columns.  Is your method applicable for long and slender columns as defined in IS code?
Please don't get angry if I have asked a silly question.
With kind regards,
N. Prabhakar
Chartered Structural Engineer
Vasai (E), Pin 401 208
rg.gupta
PostPosted: Fri Sep 06, 2019 4:30 am    Post subject: A New idea for RCC COLUMN design Reply with quote
 Dear Shree N. PRABHAKAR
jai hind
No Sir ,Not at all. If some body without going through the details & passes a immatured   remark ,then It becomes unbearable ,
without  knowing that  I am working on this concept for more than 10 years .
My special thanks to Sh V.H.VARYANI for his remarkable comments as well as his moral supports extended on this subject.
Regarding for your query for slender columns, It is ready for  release  & will be posted on SEFI .
When atleast 50 of our distinguish members of SEFI & their valuable comments are received & their suggestions are duly incorporated.
I hope this program will prove to be most  remarkable work for the design of RCC Slender of any size & shape after my next posting.
& all authorities of the world in the field will definitely surprised that the RCC column Design becomes to easy to believe & the results
are ready simultaneous to inputs given within seconds.
R G GUPTA S.E.(Retd)
CENTRAL DESIGN ORGANISATION
DELHI DEVELOPMENT AUTHORITY
91-9718829191
Sufiyan_choksi
PostPosted: Fri Sep 06, 2019 5:30 am    Post subject: A New idea for RCC COLUMN design Reply with quote
thanks can we talk?may i have your book?
On Fri, Sep 6, 2019 at 10:31 AM uhvaryani <forum@sefindia.org (forum@sefindia.org)> wrote:
           Dear Sefians, The work of Er.R.G.Gupta on column design is original and it is highly appreciated.I wish to give here the work already done by other engineers in the field of RCC column design.Most of the work available refers to rectangular and circular sections.For other sections like L-shaped,T-shaped or triangular shaped columns,we need more work.I hope Er,R.G.Gupta's method can be applied to these shapes too.
  Ghanekar and Chandra's Handbook is being used extensively in design offices.
Professor S.N.SINHA and his students of IIT,Delhi have extensive work in this field.
Professor Sinha's HANDBOOK is very useful in design offices.Varyani's book on
Biaxial Bending of Reinforced Concrete Members is also a useful reference on this subject.
Engineers who have time and inclination should solve a few examples by different methods and get these compared with Er.R.G.Gupta's method for verification.
The work of Er.R.G.Gupta is highly commended and it can be used in design offices.
with best wishes and regards,
uhvaruani
9560435030
                Virus-free. www.avg.com
sushil_singh
PostPosted: Fri Sep 06, 2019 1:05 pm    Post subject: Re: A New idea for RCC COLUMN design Reply with quote
Is the original post deleted? Can 't see it.
sukanta.adhikari wrote:
DEL
rg.gupta
PostPosted: Fri Sep 06, 2019 3:30 pm    Post subject: COL DESIGN Reply with quote
dear sefians
jai hind
as some query was raised by a member ,this was  duly clarified by re- sending the  excel file over
 the inputs of example no 8 of SP-16 on page  105 for information to all.
R G GUPTA
- Forwarded message
From: Rg Gupta <rg.gupta41@gmail.com (rg.gupta41@gmail.com)>
Date: Fri, Sep 6, 2019 at 7:03 PM
Subject: Re: COL DESIGN
To: Gunaseelan M <guna132001@gmail.com (guna132001@gmail.com)>
Jjai Hind
Thanks for your sincere comments .
Pl see the attached file for details  as per inputs given on page 105 of  example 8 of SP-16 .
It is further clarified that the moments i.e. Mx is parallel to Bx and My is parallel to Dy and re-execute and discuss.
R G GUPTA
On Fri, Sep 6, 2019 at 5:41 AM Gunaseelan M <guna132001@gmail.com (guna132001@gmail.com)> wrote:
[quote]Dear R.G. Gupta Ji                                         Namaskar.  CONGRATULATIONS for good initiative.
I have gone through your Excell col design programme, compared with the worked out example of col biaxial design given in SP-16. The following notations are not clear in your programme,so i have assumed as follows
1. P       AXIAL UN-FACTORED LOAD
2. MX    UN-FACTORED MOMENT ABOUT X AXIS
3. MY     UN- FACTORED MOMENT ABOUT Y AXIS
                  Accordingly the result steel area given your programme is As= 3428 sq.mm  against   3053 sq.mm
a difference of 12.28% on higher side.
M.Gunaseelan
EXE.ENGINEER(RETD) CPWD. CHARTERED ENGINEER
Structural Consultant
BENGALURU-560076
mobile: 9445562080
On Wed, Sep 4, 2019 at 8:01 PM Gunaseelan M <guna132001@gmail.com (guna132001@gmail.com)> wrote:
[quote]Ok, I will do it.
gunaseelan
On Wed, 4 Sep 2019, 6:29 pm Rg Gupta, <rg.gupta41@gmail.com (rg.gupta41@gmail.com)> wrote:
[quote]DEAR GNASEELAN M
JAI HIND
pl find attached herewith the excel file as requested .it will be appreciated if you pl compare this  program with your past work of at least for 10 nos of design of columns and send a report of these results.
thanks
R G GUPTA
On Wed, Sep 4, 2019 at 4:30 AM Gunaseelan M <guna132001@gmail.com (guna132001@gmail.com)> wrote:
[quote]PL SEND THE EXCEL  SHEET FOR STUDYING.
Program_for_RCC_Column_Design_(all_codes).xlsx
 Filename:  Program_for_RCC_Column_Design_(all_codes).xlsx
 Filesize:  15.74 KB
 Downloaded:  298 Time(s)
sukanta.adhikari
PostPosted: Sat Sep 07, 2019 12:41 pm    Post subject: Re: A New idea for RCC COLUMN design Reply with quote
Dear sushil sir
Actually the original post was deleted .So I also deleted my post.
S adhikari
DEL
 Filesize:  259.54 KB
 Viewed:  190 Time(s)
N. Prabhakar
PostPosted: Sun Sep 08, 2019 6:34 am    Post subject: Reply with quote
I have developed Excel spreadsheets for the design of several RC members which includes  rectangular and circular columns subjected to axial compression/tensile load, uniaxial/biaxial moments, short/long columns by limit-state method as per IS: 456 - 2000.  It also includes calculation of effective length of column as per Clause 25.2 (Annex E) of IS:456-2000.
For details, please visit my website www.rcdesignspreadsheets.com.
A sample of Excel sheets for design of rectangular columns is attached herewith.
With best wishes,
N. Prabhakar
Mobile: 9322199254
Rectangular Column - Biaxial Bending.docx
 Filename:  Rectangular Column - Biaxial Bending.docx
 Filesize:  1.08 MB
 Downloaded:  337 Time(s)
PostPosted: Mon Sep 09, 2019 8:37 pm    Post subject: Re: A New idea for RCC Column design Reply with quote
I second the views expressed by our respected Er Varyani Sir and wish to appreciate Er R.G. Gupta for his original work-the earlier version of his equations was published in the Indian Concrete Journal.
uhvaruani
9560435030
Page 2 of 2
