STAAD Pro Connect Edition 22.00.00.15 Flaws in Deflection Check
SD15
PostPosted: Thu Sep 19, 2019 12:22 pm    Post subject: STAAD Pro Connect Edition 22.00.00.15 Flaws in Deflection Check Reply with quote
Hello Everyone..I work as a civil engineer in a Japanese Multinational's Oil & Gas Division..Recently I am assigned to a Russian Project where we need to use STAAD Pro Connect Edition (Version 22.00.00.15)..While designing a pipe rack in SP 16 13330 :2011, I observed there is a flaw in deflection check...Earlier I observed the same flaw in all of the previous versions of STAAD Pro (All Select Series)..While checking the deflection of a beam member subjected to Vertical and Lateral loads, STAAD is considering only the vertical deflection for interaction ratio; it is not considering the horizontal deflection generating due to lateral loads acting on it..If this is the way STAAD continues to check the deflections for members, I am sure the same should be rectified soon..
Kindly read all of the attachments..(2 No.s  STAAD files and 1 No. Excel Summary).
Read Excel file for STAAD analysis backup.
Also please get back if anything found unsatisfactory from your viewpoint..
Thanks and Regards,
Soumen Debnath
Comparative Study of Frame Design.zip
 Filename:  Comparative Study of Frame Design.zip
 Filesize:  15.74 KB
 Downloaded:  117 Time(s)
