COLUMNS MISPLACED
irfan_shaik
PostPosted: Mon Oct 14, 2019 4:18 pm    Post subject: COLUMNS MISPLACED Reply with quote
DEAR SEFIANS,
                           Hi  my name is IRFAN SHAIK iam constructing 2BHK in 660sq.ft Site dimensions are 30'x22' while marking 3 columns misplaced  now construction is in plinth level can any body guide me what can I do at this stage iamuploading the pics and my plan
 Filesize:  197.64 KB
 Viewed:  306 Time(s)
 Filesize:  191.16 KB
 Viewed:  311 Time(s)
 Filesize:  182.29 KB
 Viewed:  306 Time(s)
GF PLAN.pdf
 Filename:  GF PLAN.pdf
 Filesize:  158.51 KB
 Downloaded:  507 Time(s)
syed_A
PostPosted: Mon Oct 14, 2019 6:42 pm    Post subject: Reply with quote
Dear Mr Irfan Shaik
Bending the column bars to rectify the misplaced one is not the solution
Provide the column beam framing drawing so that a proper solution/rectification can be discussed
reagrds
PostPosted: Tue Oct 15, 2019 2:03 pm    Post subject: Reply with quote
If a horizontal bend, as done by you, is introduced in a column, that stretch will act as a cantilever beam and the steel provided for the column will not be sufficient to take care of the BM so developed. You can modify your grid pattern to get over the glitch.
mjnasar
PostPosted: Wed Nov 06, 2019 1:40 pm    Post subject: Reply with quote
Dear Engineer
Please see the attached sketch it might help you
 Filesize:  108.7 KB
 Viewed:  265 Time(s)
ShiftingColumn_006Nov19.pdf
pdf
 Filename:  ShiftingColumn_006Nov19.pdf
 Filesize:  20.29 KB
 Downloaded:  423 Time(s)
spsvasan
PostPosted: Sun Nov 17, 2019 5:16 am    Post subject: Reply with quote
Dear Er.Irfan Sheikh
I agree with Er.Jayakumar. The present condition will result in unsafe structure. Column may be taken vertically and the grid pattern may be altered
S.P.Srinivasan
thirumalaichettiar
PostPosted: Mon Feb 10, 2020 12:25 pm    Post subject: Reply with quote
Er.irfan_shaik,
As Er.Jeyakumar and Er.Sp.Srinivasan suggested it is not advisable to bend the column bars.
My suggestion id keep the column bars and live with the same location withour any kinks or bending and try to reanalysis the framing that is the beams according to the column position.
As Er.syed_A informed attach the drawing showing the exact present location so that u will get a good suggestion from others.
T.Rangarajan
