regarding combined footing design of slab beam type
jagan0819
Progressive Member
Progressive Member
PostPosted: Tue Oct 22, 2019 10:18 am    Post subject: regarding combined footing design of slab beam type Reply with quote
dear sefians
we are designing a combined footing of slab beam type for two columns which are in horizontal orientation in plan, we are  having a doubt whether the width of beam should be greater than width of column compulsorily or is it ok to provide the width of beam less than width of column ??
image attached
PRADEEP-Model.pdf
 Filename:  PRADEEP-Model.pdf
 Filesize:  9.72 KB
 Downloaded:  88 Time(s)
PostPosted: Tue Oct 22, 2019 11:50 am    Post subject: Reply with quote
What I feel is that it is immaterial if the width of the beam is slightly less than that of the column. What matters is that the beam should be sufficiently deep, not only to take care of the MB / SF, but also to impart sufficient stiffness to it, so that the BM that we idealise it to carry is actually borne by it.
jagan0819
Progressive Member
Progressive Member
PostPosted: Wed Oct 23, 2019 1:50 pm    Post subject: thank u for valuable suggestion sir Reply with quote
thank u sir
