FLAT SLAB - COLUMN DROP
paramesh
PostPosted: Tue Oct 29, 2019 3:49 am    Post subject: FLAT SLAB - COLUMN DROP Reply with quote
Dear Sirs,
In flat slabs, can we provide the drop thickness near the columns projected upwards with bottom surface flushed with the slab as shown in the attached section-AA, to have more clearance below the slab. There is filling above the slab.
Are there any design/detailing issues if we provide like this. Please share your views on this.
PARAMESH.
FILE 1.pdf
 Filename:  FILE 1.pdf
 Filesize:  10.08 KB
 Downloaded:  115 Time(s)
sktrisal
PostPosted: Tue Oct 29, 2019 11:30 am    Post subject: FLAT SLAB - COLUMN DROP Reply with quote
It is ok if it is the last floor it can be provided with waterproof  plaster for the upstands. Sktrisal
On Tue, 29 Oct 2019, 15:56 paramesh, <forum@sefindia.org (forum@sefindia.org)> wrote:
           Dear Sirs,
PARAMESH.
Download Attachments:
FILE 1.pdf
PostPosted: Tue Oct 29, 2019 2:56 pm    Post subject: Reply with quote
Your proposal of providing Drops above the flat slab shall hold good to take care of Shear. But, you may have to provide bigger size (width) for the drops, in order to accommodate the steel at top for the negative moment. Anyway, you have to fill the remaining sunk area. You can consider filling this area with the same concrete to maintain level surface, if the additional cost involved is marginal. In other words, your flat slab becomes one without Drops.
paramesh
PostPosted: Wed Oct 30, 2019 5:34 am    Post subject: Reply with quote
Thanks for your reply.
PARAMESH.
sivaraj
PostPosted: Wed Oct 30, 2019 8:21 am    Post subject: Reply with quote
This is the normal practice in Underground Metro Station, Underground Metro Station Roof Structures are provided with inverted Drop Condition,. Check for the Two-way shear and Shuttering arrangement in site.
Sivaraj J
paramesh
PostPosted: Fri Nov 01, 2019 7:24 am    Post subject: Reply with quote
Hi,
Thank you for sharing the information.
sivaraj wrote:
Sivaraj J
2feeq008
PostPosted: Sat Nov 02, 2019 12:30 pm    Post subject: FLAT SLAB - COLUMN DROP Reply with quote
Design your beam along the area as capping beam. Regards
On Tue, Oct 29, 2019, 11:26 AM paramesh <forum@sefindia.org (forum@sefindia.org)> wrote:
           Dear Sirs,
PARAMESH.
FILE 1.pdf
