| | | | Above table gives certain information, pertinent Solar System, based on various references used from web | | | | | | | |
| | Solar system comprising of various planets is working in dynamic equilibrium | | | |
| | All planets are revolving around their repective axes, continuously | | | | |
| | Planets other than Sun are also, revolving around Sun with defined velocities/speeds | | |
| | How many days does one planet consume to move around at its axis are indicated | | |
| | How many days does one planet consume to move around Sun are indicated | | | |
| | Diameter & Volume of each planet is indicated | | | | | |
| | Each planet own rotating speed & speed around Sun (Orbital speed) are indicated | | |
| | Propulsion force produced by each planet, except Sun, because of Orbital movement is indicated | |
| | Respective Centrifugal Forces are also, indicated | | | | | |
| | Parameters respecting Sun are indicated seperately, because Sun does not rotate around itself, but only on its axis |
| | Earth rotates on its axis @ 1636 KM/HR & Around Sun @ 108088 KM/HR | | | |
| | Escape Velocity of Sun is 2223720 KM/HR, means there exists no planet that can face Sun's self revolving Velocity |
| | Diameter of Sun is 13.91 Million KM, whereas, Earth is only 12500 KM in Diameter | | |
| | Amazingly, Sun's Internal Propulsion Force is enormously Number of Times of other Planets' Propulsion Force |
| | This Number varies from minimum 47 to maximum 78581 for Jupiter & Mars respectively | | |
| | For Earth, it is only 3631 | | | | | | | |
| | Earth is moving around Sun @ 108088 or more, which is highest planetary speed around Sun among all other planets |
| | If, some missile or racket attacks surface of Earth from space, Earth could be Jeopardised very badly | |
| | If, some racket is launched from Earth for a trajectory to enter space & then commanded to return to Earth to attack it, |
| | Earth can be endangered & its existence can be challenged by some devils minds | | | |
| | No vehicle could be designed & built to reach to Sun & even, if it reaches Sun, | | | |
| | it does not look feasible to have a speed of say 2.5Million/Hour, When it reaches | | |
| | Illumination power at Sun is 38300000000000000000000000 Watts, which is impossible to be digested | | | |
| | Earth produces Propulsion Force 60900000000000000000000000 TKM/Hour, Highest among all Planets, except Sun | | |
