Opinion on Floating Column Resting Beam/Girder
Er.Ajith_K
PostPosted: Sun Feb 02, 2020 1:23 pm    Post subject: Opinion on Floating Column Resting Beam/Girder Reply with quote
Greetings,
I have doubt regarding girder for resting floating column. I need members opinion on it. I have attached image of the column layout and beam details what my structural engineer has given me in this post for your reference.
My friend who is a structural engineer and me had an argument that he suggested me to use full length reinforcement for positive curtailment (Second Layer). I told if I do that then my steel quantity will increase and it will add up my cost.
Beam (where floating Column going rest) :- 450mm x 600mm
Supporting Column :- 300mm x 450mm
Clear Span: 6 metre
Beam top Reinforcement : #3-25Y & #2- 20Y
Beam Bottom Reinforcement:
Layer 1 (Full Length) - #5-20Y
Layer 2 (Curtailment) - #4-25Y & #1-20Y and two bent up bars of 16mm where floating column going to rest.
The Beam and column are actually designed for Fe500 but we are using Fe550 due to availability & M20 grade concrete.
Building : G+3 Floors and (Ground Floor is full of car parking).
My Question:
1. Should I need to provide full length reinforcement for Layer 2 (Curtailment) or shall i go with design given by my structural engineer ?
2.Kindly view the column Layout and share your opinion, where one side of beam will be  150mm away from due to dimension and orientation ?
With Regards
Ajith
 Filesize:  73.31 KB
 Viewed:  58 Time(s)
 Filesize:  74.7 KB
 Viewed:  53 Time(s)
thirumalaichettiar
PostPosted: Sun Feb 09, 2020 6:25 am    Post subject: Reply with quote
Dear Er.Ajith,
First of all the FLOATING COLUMNS are not acceptable in case of Seismic regions. Even if the seismic reign is it it is not a good structural option.
From the sketch it is seen that the position of floating column is in such a situation that it may cause torsion as well. I do not know if he accounted for it. Since full drawing or plan is not known it may be possible to avoid it by providing secondary beams etc.
But the Floating columns in many cases are standing since they are not yet subject to EQ forces.
T.Rangarajan
