Load calculation for G+2 building(Staad.pro & Manual)
sathyace
PostPosted: Thu Jan 30, 2020 6:47 am    Post subject: Load calculation for G+2 building(Staad.pro & Manual) Reply with quote
Hi All,
I have calculated the column loads for g+2 building in staad.pro software using plate elements and also calculated the loads manually by influence area method to cross verify both software and manual calculation.
I have added all the column loads from staad.pro software which is 2% higher than the manual calculation.
So,is this difference is ok or we need to get the exact values??
Kindly provide your valuable suggestions.
Here i have attached the staad file for your reference.
Thanks & Regards,
Sathya.
G+2.zip
 Filename:  G+2.zip
 Filesize:  151.21 KB
 Downloaded:  335 Time(s)
sathyace
PostPosted: Tue Feb 04, 2020 11:32 pm    Post subject: Reply with quote
Hi all,
Please provide your suggestions on the above topic.
Thanks,
Sathya.
PostPosted: Fri Feb 07, 2020 1:41 am    Post subject: Reply with quote
Dear Sathya,
Influence area method is more of an approximation, while the plate-beam-column modeling is an exact approach. Hence, there is bound to be some differences here and there in the column load values obtained by these 2 methods. It will be within acceptable limits.
sathyace
PostPosted: Sat Feb 08, 2020 10:43 am    Post subject: Reply with quote
Thank you Jaya kumar sir.
How much acceptable limit we need to consider?
Sathya.
PostPosted: Sat Feb 08, 2020 11:03 am    Post subject: Reply with quote
We cannot define the value of such limits. All such approximations & uncertainties, which are within tolerance, will be taken care of by the factors of safety in the design.
thirumalaichettiar
PostPosted: Sat Feb 08, 2020 1:45 pm    Post subject: Reply with quote
Sathya.
Dear Er.Sathya ,
I went through ur mail sent to me and u informed there is a difference of 5% . Since STAAD calculate with the input of density and E value for the self weight and the difference from manual and if u use plate element the calculation may be FEM rather than stiffness method.
Anyway the difference upto 10% can be acceptable. Since the dimension and the area of steel provided will be usually more than the required based on the number and size of the bar.
Hope it is clear.
The above is based on my own experience.
T.Rangarajan
thirumalaichettiar
PostPosted: Sat Feb 08, 2020 1:48 pm    Post subject: Reply with quote
You can also use other software like Etabs,Nisa Design Studio or Tekla structural designer for cross verification.I am following the above technique for all my projects.
T.Rangarajan
PostPosted: Sat Feb 08, 2020 2:39 pm    Post subject: Reply with quote
Welcome, Rangarajan sir, after a long absence from the group. I think, FEM is an advancement of Stiffness method.
thirumalaichettiar
PostPosted: Sat Feb 08, 2020 2:46 pm    Post subject: Reply with quote
Er.Jayakumar,
Thanks.
Yes! FEM is an advance tool and stiffness is another tool that r used in almost many software.
If u use plate beam element by using mesh generation the STAADPRO follows the FEM method.
T.Rangarajan
sathyace
PostPosted: Sun Feb 09, 2020 4:17 pm    Post subject: Reply with quote
Thank you rangarajan sir.I have not cross checked with other softwares like ETABS. I will check and let you know the results.
Sathya.
