Field Engineering Talks on FB and Others
Goto page Previous  1, 2, 3 ... 133, 134, 135 ... 150, 151, 152  Next
suraj
PostPosted: Fri Sep 24, 2021 9:14 am    Post subject: Field Engineering Building+General+Soil+FIDICSilver-Quality+Mechanical Cleaning Plant Reply with quote
Buildings Practice Facilities Plants-Petrochemicals+Quality+Mechanical Cleaning Plant
Chapter 8
Building Design Concept
Chemical Plants
1     Contractor shall procure these items in accordance with project specifications / data sheet, included within FEED dossier (and covered in equipment list) after review, verification and detailed engineering and design.
2     Coarse screening shall be performed at fixed bar screens, installed at screen yard upstream of pumps houses.
3     Common traversing trash rake (grab bucket cleaner) and debris collection system shall be installed, as covered within applicable specifications / datasheets.
4     Screen bar material shall be required to accomplish detachment / retarding of marine shells clinging to bars.
5     Rotary drum screens are to be installed for finer (mesh opening 3 x 3 mm) screening before seawater (service fluid) is fed for further pumping and construction materials requirements are covered within applicable specifications / datasheets.
6     Contractor shall provide falling object protection for drum screens, respecting to that design approval of company/client shall be required.
suraj
PostPosted: Fri Sep 24, 2021 9:17 am    Post subject: Field Engineering Building+General+Soil+FIDICSilver-Quality+Utility Services Reply with quote
Buildings Practice Facilities Plants-Petrochemicals+Quality+Utility Services
Chapter 8
Chemical Plants
Utility Services
1     Contractor shall procure these items in accordance with project specifications / datasheets, included within FEED dossier (and covered in equipment list) after review, verification and detailed engineering and design.
2     Utility services include instrument air compressor-dryer packages, portable submersible pumps (for emptying compartments of pump sump pits, receiving basin) and pumps for draining of piping sections / manifolds.
3     Utilities services also, includes all underground services for all purposes, such as sewerage system, rain or storm water system, chemical discharge & all other included services per scope of contract
suraj
PostPosted: Fri Sep 24, 2021 9:19 am    Post subject: Field Engineering Building+General+Soil+FIDICSilver-Quality+Lifting Equipment Reply with quote
Buildings Practice Facilities Plants-Petrochemicals+Quality+Lifting Equipment
Chapter 8
Chemical Plants
Lifting Equipment
Pump Houses and Screen-Yard Cranes (Common crane and additional cranes):
1     In phase of project extending of existing 60t / 40t capacity EOT crane at pump house and 10T capacity semi portal crane at screen-yard is envisaged.
2     Common crane study report included in FEED dossier provides details of modification to be implemented.
3     Besides this, an additional crane requirement at above two locations is subject to decision based on RAM [Reliability Admissibility / Accessibility, Maintainability] study recommendation.
4     Contractor shall carryout RAM [Reliability Admissibility / Accessibility, Maintainability] study to ensure / confirm requirement respecting additional cranes at pump house and screen yard.
5     Contractor shall procure these items in accordance with project specifications / datasheets, included within FEED dossier after review, verification and detailed engineering and design.
suraj
PostPosted: Fri Sep 24, 2021 9:21 am    Post subject: Field Engineering Building+General+Soil+FIDICSilver-Quality+Lifting Equipment Reply with quote
Chapter 8
Chemical Plants
Lifting Equipment
Manifold Area Cranes:
1     Phase II of project facilities envisages cranes to handle CCVS and isolation valves installed at manifold area.
2     This new facility requirement is addressed in material handling study report and FEED dossier equipment list, which documents cover required equipment to be installed for servicing of manifold area items.
Other Handling / Lifting Facility:
1     Contractor shall procure and supply all material handling items, covered within equipment list, as stated within material handling study report, which would be updated, during detailed engineering stage, after review and verification.
2     Contractor shall prepare procurement engineering dossier, when required for procurement of off shelf items, such as manual chain hoist, with trolley on monorail beam etc. and supply same.
Mobile equipment viz. Mobile Crane, Fork Lifts etc.
1     To assist transportation and handling of materials are not covered within equipment list / material handling studies.
2     Being construction / operation aids, these mobile facilities are envisaged to be directly purchased by company / client, while only, guiding specification / data shall be provided by contractor, per detail engineering developments.
suraj
PostPosted: Fri Sep 24, 2021 9:30 am    Post subject: Field Engineering Building+General+Soil+FIDICSilver-Quality+Lifting Equipment +Noise Control Reply with quote
Buildings Practice Facilities Plants-Petrochemicals+Quality+Lifting Equipment +Noise Control
Chapter 8
Chemical Plants
Lifting Equipment
Noise Control
Contractor shall be responsible for, but not be limited to following:
1     General requirements (refer to company / client corporate philosophy for fire & safety company / client- environment protection national law)
2     Contractor shall comply with all rules, guidelines, regulations, procedures, programmes and policies in ‘environmental guidelines & environmental protection criteria for plant industrial city’ during execution of work.
3     Environmental guidelines & environmental protection criteria for plant industrial city
4     Initial calculation shall be based on equipment meeting sound level and sound power level limits of company / client specification.
5     Final calculation shall be based on vendor quoted and tested equipment sound levels.
6     These calculations shall be included, within an initial and final report, which should be submitted for company / client approval.
Such reports shall contain following requirements:
1     Equipment list giving equipment physical data, such as size, speed and power.
2     Equipment location.
3     Estimated industrial community sound level at company / client determined locations.
4     Estimated sound level contours, including in plant areas, at fence line and at inner edge of perimeter infrastructure road in 2.5-decibel (dba) increments.
5     Equipment sound power levels used in model.
6     Equipment sound levels at one meter.
7     Noise control treatments proposed.
8     Vendor sound level reports with vendor’s shop test reports.
9     Final report shall be called ‘noise control design basis - summary report’.
10     Contractor shall conduct a coordinated overall noise control program, including cost effect comparisons.
11     In addition, contractor shall recommend such alternative or additional acoustical design features or treatment, as necessary to meet functional & project requirements.
12     Contractor shall ensure that sound pressure level of cooling water pumps shall not exceed values specified within contract by applying whatever attenuation devices.
13     Contractor shall be responsible for identifying necessary required reduction of equipment sound level limits specified, within company / client specification to ensure compliance with facility sound level provisions.
suraj
PostPosted: Fri Sep 24, 2021 9:32 am    Post subject: Field Engineering Building+General+Soil+FIDICSilver-Quality+Environmental Control Reply with quote
Buildings Practice Facilities Plants-Petrochemicals+Quality+Environmental Control
Chapter 8
Chemical Plants
1     Contractor shall be responsible for, but not be limited to following requirements:
General Design Requirements
1     Contractor shall finalise design documents incorporating design data, including emission data obtained from Vendor’s.
2     Contractor shall be responsible for compliance with local environmental control regulation and project specifications, provided within contract.
3     In general, facility should be designed to meet ambient air quality and water quality guidelines, meeting national regulations, as specified within project specifications.
Engineering Evaluations
1     Contractor shall verify or finalise engineering evaluations, ensuring that environmental control systems, as designed comply with applicable regulations.
suraj
PostPosted: Fri Sep 24, 2021 10:27 pm    Post subject: Field Engineering Building+General+Soil+FIDICSilver-Quality+SHE Reply with quote
20 Minutes Video
25.09.2021-Civil Field Engineering + Life + Quality AnnexSL + COVID-19 + SHE+ Engineers Role + Designs + Construction + Methods + Contracts + Organisations + Communication + Coordination + Why be behind Quality of Standard Material + Works? Talk 515
https://www.facebook.com/pesuraj/videos/222533359937088
suraj
PostPosted: Fri Sep 24, 2021 11:12 pm    Post subject: Field Engineering Building+General+Soil+FIDICSilver-Quality+SHE Reply with quote
16 Minutes Video
https://www.facebook.com/pesuraj/videos/224960022998036
suraj
PostPosted: Sat Sep 25, 2021 9:05 am    Post subject: Field Engineering Building+General+Soil+FIDICSilver-Quality+Building Design Concept+Cathodic Protection System Reply with quote
Buildings Practice Facilities Plants-Petrochemicals+Quality+Building Design Concept+Cathodic Protection System
Chapter 8
Chemical Plants
1     Cathodic protection (CP) is a technique used to control corrosion of a metal surface by making it cathodic side of an electrochemical cell
2     Cathodic protection systems are used to protect a wide range of metallic structures in various environments.
3     Most common applications include: Water and fuel pipelines
4     Cathodic Protection (CP) is a technique, used to control corrosion of a metal surface by making it cathode of an electrochemical cell.
5     A simple method of protection connects metal to be protected to a more easily corroded "sacrificial metal" to act as anode.
6     Sacrificial metal then corrodes, instead of protected metal.
7     For structures, such as long pipelines, where passive galvanic cathodic protection is not adequate, an external DC electrical power source is used to provide sufficient current.
8     Cathodic protection systems protect a wide range of metallic structures in various environments. Common applications are: steel water or fuel pipelines and steel storage tanks, such as home water heaters; steel pier piles; ship and boat hulls; offshore oil platforms and onshore oil well casings; offshore wind farm foundations and metal reinforcement bars in concrete buildings and structures.
suraj
PostPosted: Sat Sep 25, 2021 9:06 am    Post subject: Field Engineering Building+General+Soil+FIDICSilver-Quality+Building Design Concept+Cathodic Protection System+Galvanic Reply with quote
Buildings Practice Facilities Plants-Petrochemicals+Quality+Building Design Concept+Cathodic Protection System+Galvanic
Chapter 8
Chemical Plants
Galvanic
1     Another common application is in galvanized steel, in which a sacrificial coating of zinc on steel parts protects them from rust.
2     Cathodic protection can in some cases, prevent stress corrosion cracking.
3     In application of passive cathodic protection, a galvanic anode, a piece of a more electrochemically "active" metal (more negative electrode potential) is attached to vulnerable metal surface, where it is exposed to an electrolyte.
4     Galvanic anodes are selected, because they have a more "active" voltage than metal of target structure (typically steel).
5     Concrete has a pH around 13.
6     In this environment, steel reinforcement has a passive protective layer and remains largely stable.
7     Galvanic systems are "constant potential" systems that aim to restore concrete's natural protective environment, by providing a high initial current to restore passivity.
8     It then reverts to a lower sacrificial current, while harmful negative Chloride ions migrate away from steel and towards positive anode.
9     Anodes remain reactive through their lifetime (10-20 years typically), increasing current, when resistivity decreases, due to corrosion hazards, such as rainfall, temperature increases or flooding.
10     Reactive nature of these anodes makes them an efficient choice.
11     Unlike ICCP systems, steel constant polarization is not goal, rather restoration of environment. Polarization of target structure is caused by electron flow from anode to cathode, so that two metals must have a good electrically conductive contact.
12     Driving force for cathodic protection current is value difference in electrode potential, between anode and cathode.
13     During initial phase of high current, potential of steel surface is polarized (pushed) more negative, protecting steel, which hydroxide ion generation at steel surface and ionic migration restore concrete environment.
14     Over time, galvanic anode continues to corrode, consuming anode material, until eventually it must be replaced.
15     Galvanic or sacrificial anodes are made in various shapes and sizes, using alloys of zinc, magnesium and aluminium.
16     ASTM International publishes standards on composition and manufacturing of galvanic anodes.
17     In order for galvanic cathodic protection to work, anode must possess a lower (that is, more negative) electrode potential than that of the cathode (target structure to be protected).
Page 134 of 152
