STAAD Design Summary & ETABS Design Summary Extraction Program
someshwar ganti
PostPosted: Sun Jun 21, 2020 4:49 pm    Post subject: STAAD Design Summary & ETABS Design Summary Extraction Program Reply with quote
Hello everybody
I have written a program to Extract the Design Summary data of a RCC Building from
   STAAD output file (*.ANL)
   Etabs Database File (all Tables Selected) (*.MDB, *.ACCCDB) file
The program will extract the Beam summary (Reinforcement or Design Forces)
   Arrange summary Row wise (Left To Right) output will be in format of
     1. PDF file
     2. Excel file
     3. AutoCAD Drawing (a Single line drawing of all the beams in the selected Level/Floor) showing the reinforcement.
The program will extract the Column Summary (reinforcement or Design Forces)
   Arrange the Summary Column wise (Bottom column to Top most column)
     1. PDF File
     2. Excel File
The program will also Generate
   1. Footing Layout, Column Layout Drawings
   2. Footing Details & Column Detail Drawings
   3. Beam Layout Drawing
   4. Beam Longitudinal Section Drawings
      (the reinforcement is extracted from STAAD/ETABS file, can be edited using Excel as per user requirements)
Host of many Plugins useful for a Design Engineer & Draftsman
you can download the Trial Version of the program from
ARC BDS (32 bit Version)
ARC BDS (64 Bit Version)
Also, STAAD Design Summary Extractor for EURO Code, can be downloaded from
STAAD Design Summary Extractor (EURO CODE)
STAAD Column Reinfrocement Summary REPORT.pdf
 Filename:  STAAD Column Reinfrocement Summary REPORT.pdf
 Filesize:  13.43 KB
 Downloaded:  103 Time(s)
STAAD Column Design FORCES Report.pdf
 Filename:  STAAD Column Design FORCES Report.pdf
 Filesize:  18.85 KB
 Downloaded:  77 Time(s)
STAAD Beam Renforcement Summary REPORT.pdf
 Filename:  STAAD Beam Renforcement Summary REPORT.pdf
 Filesize:  99.48 KB
 Downloaded:  68 Time(s)
STAAD Beam Reinforcement Summary (as AutoCAD Drawing).pdf
 Filename:  STAAD Beam Reinforcement Summary (as AutoCAD Drawing).pdf
 Filesize:  66.92 KB
 Downloaded:  70 Time(s)
ETABS Column Reinforcement Summary REPORT .pdf
 Filename:  ETABS Column Reinforcement Summary REPORT .pdf
 Filesize:  16.6 KB
 Downloaded:  62 Time(s)
ETABS Beam Reinforcement Summary REPORT .pdf
 Filename:  ETABS Beam Reinforcement Summary REPORT .pdf
 Filesize:  70.68 KB
 Downloaded:  54 Time(s)
ETABS Beam Reinforcement Summary (as AutoCAD Drawing).pdf
 Filename:  ETABS Beam Reinforcement Summary (as AutoCAD Drawing).pdf
 Filesize:  153.46 KB
 Downloaded:  67 Time(s)
Thankful People
