Anurag_Tripathi SEFI Member
Posted: Thu Jun 04, 2020 6:34 pm Post subject: Evaluate my model |
Can you check my model for the following
1. If Moment release in secondary beam is applied correctly
2. I am getting warning for zero stiffness and THERE WERE MORE THAN 12 DOF WITH ZERO STIFFNESS
3. I Am getting Warning -
INSTABILITY AT JOINT 981 DIRECTION = MX PROBABLE CAUSE SINGULAR-ADDING WEAK SPRING K-MATRIX DIAG= 2.1514374E-01 L-MATRIX DIAG= -3.4917359E-13 EQN NO 3139 ***NOTE - VERY WEAK SPRING ADDED FOR STABILITY
4. There is a beam still failing in even after increasing the size and releasing moment
I am learning Staad Pro so kindly help me these problems
Thank You |
