Torsional requirements clause
Challa
PostPosted: Thu Aug 06, 2020 12:31 am    Post subject: Torsional requirements clause Reply with quote
Hello everyone,,
Suppose at one end at terrace horizontal deflection is 1 mm and at other end it is 1.8mm.Both are negligible.shall we ignore?Is there any clause in code that refers to minimum deflection below which the clause....7.1 ..3A TORSIONAL IRREGULARITY is not applicable.
https://snaptube.cam/https://9apps.cam/
VPandya
PostPosted: Fri Aug 07, 2020 8:30 pm    Post subject: Can you send the picture of your deflected beam . This is weak axis moment My . Reply with quote
Er. Challa ,
Can you send the picture of your deflected beam . This is a weak axis moment  My .
TYPICALLY ( IN STAAD/PRO  LOCAL  AXIX  SYSTEM)  :
Node I to J along the Span of beam is the X axis
MZ  is the STRONG AXIS MOMENT  .
MY  is the WEAK AXIS  MOMENT (Caused by deflection you are giving )
MX  is the TORSION
You have "  My "  Weak Axis moment not TORSION .  TORSION Moment comes from applied load eccentric to span of beam by a bracket attached to beam . A vertical load applied at the end of the Bracket . I think you have Weak Axis Moment  " My"  not torsion .
Send the picture of your deflected beam . You have to design for weak axis moment My .
Regards.
Vasudeo Pandya  P.E.
Structural Engineer
hemalmistry
PostPosted: Sat Aug 08, 2020 6:42 am    Post subject: Re: Torsional requirements clause Reply with quote
This one is valid situation, not addressed in code. However, in one of the international codes, such situation is handled as attached here, which states that if actual drift is very less than permissible drift, suitable relaxation may be given to torsional irregularity requirement.
Hemal Mistry
 Filesize:  134.95 KB
 Viewed:  25 Time(s)
VPandya
PostPosted: Sat Aug 08, 2020 3:41 pm    Post subject: What I was talking was TORSIONAL MOMENT IN A MEMBER not plan irregularity. Reply with quote
Er. Mistry ,
What I was talking about was TORSIONAL MOMENT IN A MEMBER/ A BEAM  not plan irregularity of a whole building .  IN A CHANNEL SHAPE , " L"  SHAPE  AND " T "  SHAPE PLAN LAYOUT OF BUILDINGS WE HAVE TO CONSIDER TORSIONAL EFFECTS OF WHOLE BUILDING WITH A 3-D COMPUTER MODEL .
Regards.
Vasudeo Pandya P.E.
Structural Engineer
