How do you build dams and bridges that stand on water while there is still water in the body that can interfere with the
Camano
PostPosted: Thu Nov 19, 2020 10:17 am    Post subject: How do you build dams and bridges that stand on water while there is still water in the body that can interfere with the Reply with quote
By diverting the river flow by means of tunnels if the geography allows for it or by building cofferdams.
For instance in the case of hoover dam, where the river flows through a deep gorge, the river was diverted through two tunnels on either side of the river and building a coffee dam Infront. The dam is constructed in the resulting dry area https://trackeasy.fun/usps/ https://showbox.tools/.
In certain cases where tunnel construction is not feasible or possible, the dams are usually constructed by means of cofferdams. A cofferdam structure is made like a fence around the working area half at a time. This can be either by means of dumping sand and rocks or by thrusting down sheet piles. Once the water trapped inside the cofferdam is pumped out, the construction can begin.
md zeeshan ali
Progressive Member
Progressive Member
PostPosted: Fri Nov 20, 2020 3:22 pm    Post subject: Reply with quote
Dear Sir
In our project located at Jehanabad , we used the offshoot of river Fhalgu  to  divert the seasonal stream of River to construct the weire  in lenth of  River  with  undersluice on the both side of the weir.
Best Regards
Md Zeeshan ali
