Maximum Size of Fillet Weld for T-joints
PostPosted: Thu Apr 22, 2021 6:17 pm    Post subject: Maximum Size of Fillet Weld for T-joints Reply with quote
I received the following question from a fellow engineer
Is it possible to have 8 mm fillet weld for T joint of 10 mm plates?
Can we follow Max weld size= Min plate thk-1.5mm? I could not find relevance in code or book for T joint, for corner joints it is clearly covered.
My Reply:
There is NO max size of fillet weld for a T-joint, to AWS and AISC specifications.
The max fillet weld rules are for 'edges' - so that the edges are not melted.
For a T-joint there are no 'edges', just 'surfaces'.
Image courtesy: From AISC Design Guide #21 'Weld connections - A Primer for Engineers'
Image courtesy: Er. Duane Miller's recent AISC webinar on Welding
However, it may be prudent to limit the maximum size of weld to that of the minimum size of plates being joined.
PostPosted: Fri Apr 23, 2021 4:53 am    Post subject: Reply with quote
Maximum fillet weld size
Just quoting from IS 816
Cl 6.2.2 Size of fillet weld shall not be less than 3mm, nor more than the thickness of thinner part joined.
Cl 6.2.5.1 Where a fillet weld is applied to the square edge of a part, the specified size of weld would generally be 1.5mm less than the edge thickness to avoid washing down of exposed arris.
Dr NS sir has already answered  very nicely citing  other international codes.
For a T joint , maximum size of fillet weld  (in line with clause 6.2.2 of IS 816) is the thickness of thinner plate. No need to minus 1.5 mm.
sakumar79
PostPosted: Fri Apr 23, 2021 8:20 am    Post subject: Reply with quote
Dear Senior engineers,
     We often have to deal with tube sections which have thickness as small as 2 mm or 2.6 mm. How to adopt weld thickness in such cases? Min thickness of 3 mm and max of thinner sections will be contradictory. Also, is it practical to specify weld thickness with 0.1 mm accuracy like 2.6 mm or only rounded off thickness like 2 mm is practical to execute at site?
Thanks in advance
Yours sincerely
S Arunkumar
PostPosted: Fri Apr 23, 2021 9:31 am    Post subject: Reply with quote
Dear Er
Clause 6.2.2 though contemplates minimum fillet weld size as 3mm , but also refers to Table 1 linked to this clause. This table 1 gives minimum size of first run or Single run fillet weld.
As per footnote 1 it is clearly stated that when the minimum size of fillet weld given in table is greater than thickness of thinner part, the weld should be equal to thickness of thinner part..  If thickness is 2mm (  for 15mm circular  steel tube -light wt OR 2.6mm for 25mm hollow sq pipe ) , the weld size shall not be greater than thickness.
sakumar79
PostPosted: Fri Apr 30, 2021 7:29 am    Post subject: Reply with quote
vikram.jeet wrote:
Dear Er
Dear Er Vikram Jeet,
   Thank you for the clarification. Also please clarify if accuracy of 0.1 mm in specifying weld thickness is practical from execution point of view.
Yours sincerely
S Arunkumar
PostPosted: Fri Apr 30, 2021 9:00 am    Post subject: Reply with quote
Dear Er Arun ji
The tolerance limits for welding
In my opinion  ,it is not desirable to give the tolerance value , it shall conform to some standard of BIS , otherwise to specification s of Govt Publications like CPWD specs.e tc.
May also see following standards in connection with welding
IS 9595
IS 822
