Raj Panchmatiya SEFI Member
Posted: Mon May 24, 2021 3:01 am Post subject: Effective length parameters ELY and ELZ in STAADPro |
Please the the attached pdf to clear your doubts regarding ELY and ELZ in Staadpro.
ETABS will automatically calculate these parameters. However, in STAADPro, we need to calculate and provide these design parameters.
ELY/ELZ = Effective length factor * Unsupported length divided by actual length of column
Effective length factor for RCC = 1.2
and Unsupported length depends on restraints provided by the beam to resist buckling in that direction. For example, consider a column of length 3m which is supported by a beam at 1.5 m height in Z direction and supported by a beam at 3m height in y direction. Therefore, Unsupported length in Y direction will be 1.5m because bending in Y direction is resisted by the beam provided in Z direction at 1.5m height. Similarly, unsupported length in Z direction is 3m because bending in Z direction i ls restrained by beam at 3m height in Y direction.
Please see the attached pdf for more clarity.
ELY and ELZ for columns.pdf |
831.89 KB |
366 Time(s) |
Thankful People |
romit(15-07, 3:39), Thanks Raj Panchmatiya for his/her post
Posted: Mon May 24, 2021 3:41 am Post subject: Re: Effective length parameters ELY and ELZ in STAADPro |
Yes, very good point / observations by Er Raj ji.
Same situation comes in diagonal members of steel bridges T russ girders , Diagonal s which have node point at center with half ht. vertical member and small diagonal from that node providing restraint in Z dir. Only. In Y direction diagonal donot have such luxury of restraint since two trusses cannot be tied at that mid ht level -traffic movement.
Request to put such observations on Sri for benefit of everyone.
Raj Panchmatiya wrote: | Please the the attached pdf to clear your doubts regarding ELY and ELZ in Staadpro.
Please see the attached pdf for more clarity. |
Posted: Mon May 24, 2021 4:42 am Post subject: |
One more situation is encountered in all buildings
At frames supporting staircase MID-LANDING beams, the column s supporting this beam have Lz of Half height , but Ly is full height.
