sukanta.adhikari General Sponsor
Posted: Fri Jun 25, 2021 2:45 pm Post subject: |
Dear Anirudh,
I have used SAFE few years before. Right now I am not having the license ,so I am not able to use it.
SAFE approach is different from STAAD. In STAAD ,we use plate element to model the raft and beam to model the connection between columns at raft level.
But in SAFE ,I remember in the training the raft was modelled with shell/element and instead of beam... the connection between column was also done using same shell/element used to model the other portion of raft. The thickness of shell/element connecting the columns were locally made thicker, since beam depth will be more than other portion of raft. But a beam was not used.
I forget the reason. You can contact CSI for help.
S Adhikari
Anirudh4569 wrote: | Dear sir,
I have monolithically modelled raft foundation with beams in safe. The supports i have applied as soil supports with subgrade modulus.
vikram.jeet wrote: | Dear Er
If analysis is carried considering foundation input as base pressure instead of springs, may please see the output , probably it may match nearer to yr manual calcs.
Also in case of springs, pl check the value of modulus of subgrade reaction entered . If value is that of rock , then also , I feel , the rock springs in vicinity of rcc columns share and beams do not reflect.
Just a generic view |
Anirudh4569 SEFI Member
Posted: Tue Jun 29, 2021 11:16 am Post subject: |
Ok sir Thankyou for your response.
sukanta.adhikari wrote: | Dear Anirudh,
S Adhikari
