How to design RCC steps with walls on it
ramu_se
PostPosted: Wed Sep 22, 2021 3:45 am    Post subject: How to design RCC steps with walls on it Reply with quote
How to design the RCC waist slab flight with walls coming on the edge of the steps.
Here i have attached the image for your reference.
Kindly share the methods to design these steps with wall.
Thank you,
Ramu.
 Filesize:  1.07 MB
 Viewed:  14 Time(s)
PostPosted: Wed Sep 22, 2021 5:23 am    Post subject: Reply with quote
STAIRS WAIST SLABS
1.0 Fligh2  need to rest on 9" th load bearing walls ,to be provided on opposite sides . In sketch only one wall is load bearing , but there is need to effect opposite wall from found level itself to support waist slab if flight 2  spanning along width of stair.
2.0 Flight 2 waist will have both upper and lower landings as cantilevered from width wise spanning sloping waist slab in longitudinal direction . Thus flight 2 sloping waist shall have top and bottom reinforcement as per design requirements.
3.0 flight 1 will be supported longitudinally , one end at GL footing and other at top by cantilevering out landing (fm flight 2 waist).
Loads from flight 1 will be transfered to flight 2 waist considering its only one meter strip in width span direction  to bear + it's own wt .
Similarly load from topmost cantilever flight to be transfered to sloping flight 2 , considering flight 2 strip of one meter .
Other option of providing + shaped wall at lower landing or Even T shaped wall , will suffice and side walls help to supports waist not required.
