GLARE AROUND THE WALT DISNEY CONCERT HALL
PostPosted: Thu Dec 30, 2021 7:21 pm    Post subject: GLARE AROUND THE WALT DISNEY CONCERT HALL Reply with quote
A project that had major reflectance problems was the new Walt Disney Concert Hall(WDCH), designed by the famous architect Frank Gehry and owned by the County of Los Angeles, which has had to call in experts in an attempt to reduce the glare and thermal issues surrounding the building.
The WDCH is partly building partly concert hall and partly a free-form sculpture. The above-grade portions include an office wing, clad in white limestone, several outdoor gardens and two outdoor amphitheaters, and two buildings clad in stainless steel. In fact, the stainless steel portion of the roof is often a freestanding curtain or skin. Much of the steel skin is curved and composed of convex and concave undulating surfaces. The bulk of the building is brushed stainless steel, but the Founders Room and the marquee for the California Institute of the Arts Roy and Edna Disney California Arts Theater (REDCAT) are made of polished stainless steel. In many ways, it is a state-of-the-art building, pushing the envelope of architecture.
In late June 2003, when the builders peeled off the film over the polished stainless steel, used to cover the steel during construction, the owners of condo apartments opposite began to complain. In mid-afternoon the glare from the steel became so intense that they had to leave their balconies, close the curtains, and put on the air conditioning for three hours until the sun went off that face of the building. The temperatures in their apartments went up by up to 15 C because of the added glare off the building. Gehry blamed the builders.
The county put a $ 6000 mesh over the steel as a stop-gap remedy, demonstrating a proactive approach to solving the problems to neighbors of heat and light pollution caused by a building they commissioned.
The County contracted Sapphos Environmental, who in turn contracted Schiler & Associates to study the impact of the building on the Promenade Towers, a commercial and residential building west of the WDCH. The thermal issues and the visual issues were addressed by Schiler & Associates separately, in order to be thorough. The former was tested with dataloggers and an infrared thermometer gun, the latter approached through a series of digitized photographs and computer simulation.
Several solutions were tested. Four different films were tested, two of which though acceptable in terms of diffusion, but not durable. One tested coated fabric was also similar. One version of sandblasting the surfaces was considered. The best solution was a combination of vibrational sanding, for coverage, followed by orbital sanding, for aesthetic reasons. The fabric solution was applied to the worst offending surfaces of the Founders Room and proved to be effective on all of the surfaces covered.
Ref: Schiler & Valmont, Microclimatic Impact: Glare Around the Walt Disney Concert Hall, https://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.729.6480&rep=rep1&type=pdf
 Filesize:  72.96 KB
 Viewed:  17 Time(s)
pvgraju
Progressive Member
Progressive Member
PostPosted: Fri Dec 31, 2021 8:24 am    Post subject: GLARE AROUND THE WALT DISNEY CONCERT HALL Reply with quote
Good information. Engineers ability to learn will enhance with these types of case studies only. New design of a structure is more common but problem solving skills are rare when actually a problem arises.
P.V.Gavarraju
spsvasan
PostPosted: Mon Jan 03, 2022 2:56 am    Post subject: Re: GLARE AROUND THE WALT DISNEY CONCERT HALL Reply with quote
[quote="Dr. N. Subramanian"]GLARE AROUND THE WALT DISNEY CONCERT HALL
Ar.Frank Gehry had problems in two more of his buildings.
In Aon centre [1973] the choice of cladding was inappropriate, resulting in damages to the thin Carara marble cladding which started falling down. The cladding had to be replaced
In Strata building at MIT [2004] an out-of-the world elevation required the building walls to be at various inclinations. The building had serious drainage issues, cracking of walls and mould growth problem.
S.P.Srinivasan
PostPosted: Wed Jan 05, 2022 4:15 am    Post subject: Reply with quote
Architect ,once conceive a structure , needs not only to focus on aesthetics but also to services , environmental issues arising out from claddings .
In this case , Architect has created a structure par excellent ,from aesthetic considerations , but such a big name in Architecture field has missed on environmental impact of claddings.  TO ERR IS HUMAN , TO CORRECT IS DIVINE .
PostPosted: Wed Jan 05, 2022 5:16 am    Post subject: Re: GLARE AROUND THE WALT DISNEY CONCERT HALL Reply with quote
[quote="spsvasan"]
S.P.Srinivasan
Thank you my friend Er Srinivasan.
I think I wrote earlier about this MIT university building designed by Ar. Gehry   and it's problems.
Warm regards
