Should most of the beams designed as columns?
PostPosted: Fri Feb 04, 2022 6:44 pm    Post subject: Should most of the beams designed as columns? Reply with quote
As per clause 6.1 of13920 when compressive stress in the beam exceeds 0.08 fck, it should be designed as a  column.  for M25 concrete, 0.08 fck = 2 MPa only. From computer analysis this value will be exceeded in most cases. Hence, should we design all beams as columns?
PostPosted: Sat Feb 05, 2022 6:17 pm    Post subject: Reply with quote
Just to say that :
Beams are predominantly Bending members but in frame beams axial forces co-exist . I think software is taking care of combined bending and axial forces including torsions.
In manual design era , also , such coexistent axial forces were considered , if appreciable.
IS 13920  guideline for considering   frame beam as compression member (column) if factored  axial stress exceeds 0.10 Fck puts all such requirements of dimensional restrictions  on beams , thus beams have to fulfill dimensional restrictions  of beams as well as column.
As regards confining reinf , beams already provide confining reinf upto 2d , ie more than Lo as  indicated for column .
But softwares need members to be designated as Beams or Columns , and there fore dimensional restrictions of width / Length to be 0.4 or more (of column)  needs to be kept in view while fixing sizing of frame beams . This value is otherwise 0.3 .
Also for beam spans more than 5.0m and clear height of column more than 4.0m the minimum dimension needs to be 300mm.
