pedestal design for light pole
Goto page 1, 2, 3  Next
dubeyratnesh
PostPosted: Fri Apr 01, 2022 9:13 am    Post subject: pedestal design for light pole Reply with quote
hello sir i want to design a pedestal with footing on soil having sbc 8 t/m2.pedestal is supporting 9m high light pole in an area having basic wind speed 50 m/s.
what approach we can follow to design this pedestal and footing
PostPosted: Sat Apr 02, 2022 3:32 am    Post subject: Reply with quote
Pedestal & footing  for high mast
Wind load is predominant and substructure is designed for moment due to wind forces on high mast body.
Generally square pedestal and square shape footing for ease of reinf placement vis a vis circular one.
Footing size as also foundation depth shall be sufficient enough to provide soil weight over footing . Footing shall be checked for overturning  . Sliding may not be a problem but to be checked .
Base pressures needs to be checked considering some upliftment of footing due to wind.
e = M/W
M is the moment at base due to wind forces
W is the wt of footing + soil wt over it + wt of steel mast
The contact length X = 3*(B/2 - e)
B is the dimension of footing in direction of moment
Contact Length percentage = (X/B)*100
Contact %  can be 67% to 80% depending on FOS against OT
Max base pressure = 2*W /( X*L)
L is the dim of footing in other direction
Some designers also consider passive soil resistance relief with some FOS provided by rcc pedestal and footing
dubeyratnesh
PostPosted: Sat Apr 02, 2022 3:38 am    Post subject: pedestal design for light pole Reply with quote
SIR ON WHAT BASIC DEPTH OF PEDESTAL WILL BE CALCULATED OVER FOOTING.
PostPosted: Sat Apr 02, 2022 10:50 am    Post subject: Reply with quote
Pedestal shall also be rcc in square crossection .
Pedestal is designed as vertical cantilever  from footing .
Depth of foundation for 9.0m mast may be minimum 2.5 m . But all depend on soil weight needed over footing . If foundation size is restricted , then higher depth of foundation is needed to achieve soil weight.
dubeyratnesh
PostPosted: Sun Apr 03, 2022 11:36 am    Post subject: Design of pedestal for electric pole Reply with quote
Thank you sir
From where we can start ? On what basis we can select hight of pedestal.? Taking factor of safety about 1.5 for overturning the hight of pedestal is coming more than 4 meter which is not feasible.a 9 meter hight pole on cyclone effected area gives more wind moment? Weight of pedestal resisting will be more? How to decide pedestal hight.further footing design?
PostPosted: Sun Apr 03, 2022 3:45 pm    Post subject: Reply with quote
You are thinking of block foundation for light pole . I think in this case Pl think of rcc spread footing with soil over it  with rcc pedestal. The concrete block foundations are feasible for low ht light poles , but not for high mast which require spread footing with rcc pedestal.
dubeyratnesh
PostPosted: Mon Apr 04, 2022 3:06 am    Post subject: Design of pedestal for electric pole Reply with quote
Sir can you provide any design example of high mast from any refrence book or previous design?
PostPosted: Mon Apr 04, 2022 4:05 am    Post subject: Reply with quote
I don't think that any ready standard design / details available , but you can search NHAI or Highways / Expressways for any ready material.
But it is a simple case of designing an isolated spread footing for Uniaxial moment. Footing need to be square as wind can blow in any direction .
PostPosted: Mon Apr 04, 2022 4:39 am    Post subject: Reply with quote
Pl see in google search details  for standard street light pole upto 35 feet high Search P-660.pdf on Google.
PostPosted: Mon Apr 04, 2022 5:03 am    Post subject: Reply with quote
Please see in google search for light pole design calcs , are available in net
Page 1 of 3
