Diagonal reinforcement at reentrant corners
hishamajmalpc
PostPosted: Tue Jan 10, 2023 6:30 am    Post subject: Diagonal reinforcement at reentrant corners Reply with quote
Dear sefinas,
Plz refer to clause 9.4.9 of SP 34 reg. diagonal reinforcement at reentrant corners. Is it necessary to provide this in all cases? Is there any design criteria for this.
pvgraju
PostPosted: Tue Jan 17, 2023 9:02 am    Post subject: Diagonal reinforcement at reentrant corners Reply with quote
Due to temperature change, shrinkage concrete tries to shrink in perpendicular directions which will cause crack at the corner. By providing diagonal reinforcement at reentrant corners this crack width will get minimized.
P.V.Gavarraju.
kunalkansara
PostPosted: Wed Mar 08, 2023 10:19 pm    Post subject: Reply with quote
Dear Engineer
What is the structure with the re-entrant corner?
Typically, the re-entrant corners (e.g., in a half-joint or dapped-end in a girder that was a popular approach in bridges constructed in the 60's and 70's) in a structural member are shear-dominant regions. The substantially high stress-concentration at such corners makes them highly prone to the crack originating from the re-entrant corners, through which the elements of nature can enter and initiate corrosion of the internal steel reinforcement and further weaken the member. Few tactics are employed to safeguard the re-entrant corners from this possibility:
Firstly, where possible, instead of a sharp re-entrant corner, chamfers are provided to ease the stress concentration to an extent.
Second, specific reinforcement detailing is provided to tackle stress concentration and forces that intend to crack open the re-entrant corner.
There are two main forms of reinforcement detailing in the re-entrant corners of a structural member :
Option A: (colloquially also known as the European detailing approach), bending up a set of main tension rebars from the bottom face of the belly of the member passing through the re-entrant corner diagonally all the way up to the top face and then bending them inwards to anchor them within the structural member. The crack at the re-entrant corner generally occurs at 45 degrees. So, the key requirement for the diagonal reinforcement is to have sufficient development lengths on either sides of the crack to make it effective in resisting tension which a potential crack is intending to generate in that region.
 Filesize:  67.79 KB
 Viewed:  18 Time(s)
 Filesize:  112.03 KB
 Viewed:  14 Time(s)
