drsunil SEFI Member
Posted: Sun Mar 19, 2023 5:55 am Post subject: Efficiency of bolted joints |
In a simple lap joint with bolts. During calculation of solid plate strength , why we calculate solid plate strength based on ultimate rupture criteria .While we should use gross section yielding . Since in solid plate there is no question of rupture . All text book use the ultimate cretria for solid plate strength.pl. explain this . |
vikram.jeet General Sponsor
Posted: Mon Mar 20, 2023 5:15 am Post subject: |
Being old timer designer ,,
For Lap joint
Plate is checked for direct tension on net area at x sec passing thru bolts,
Rupture of plate is to be checked in reference to edge distance of bolts, especially corner bolts |
drsunil SEFI Member
Posted: Mon Mar 20, 2023 5:58 am Post subject: |
Thanks sir, for reply
Actually i am asking about efficiency of joint. for efficiency we divide the strength of joint by solid plate strength. My question is that which formula/criteria should be used for calculation of solid plate strength. |
