Application of wind load on open structure
LELE AND ASSOCIATES
PostPosted: Mon Dec 11, 2023 11:43 am    Post subject: Application of wind load on open structure Reply with quote
Hello Sefians
I am designing an open shed without cladding on all four sides with a steel roof on the top, the sketch is attached herewith for reference.
I am trying to apply wind load on this structure and following example 16 of the handbook (copy attached herewith). I am unable to follow the way the handbook has explained it. Secondly, how is the load on the columns applied?
shed1.pdf
 Filename:  shed1.pdf
 Filesize:  178.16 KB
 Downloaded:  286 Time(s)
HANDBOOK FOR WIND LOAD-IS-875-PART-3.pdf
 Filename:  HANDBOOK FOR WIND LOAD-IS-875-PART-3.pdf
 Filesize:  2.4 MB
 Downloaded:  740 Time(s)
shed1.pdf
 Filename:  shed1.pdf
 Filesize:  178.16 KB
 Downloaded:  252 Time(s)
sakumar79
PostPosted: Wed Dec 13, 2023 1:50 am    Post subject: Reply with quote
Dear Sir
   You can follow example 16 for the calculation. There will be no wind load on the column directly as the shed is open. However, you may review if you need to consider the possibility of the shed being fully clad or clad on 3 sides in the future. Especially, shed being clad on 3 sides will be cricital. Both will create wind load on walls / columns.
Yours sincerely
S Arunkumar
PostPosted: Wed Dec 13, 2023 3:38 am    Post subject: Reply with quote
Wind load on open shed columns :-
I think forces from roof create column moments apart from any possibility of cladding. As follows:-
1. Difference between windward and leeward forces on sloping roof create horizontal forces at columns top. Thereby creating moments .
2. Wind uplift force  from roof on columns creating direct tensile force in columns
3. Even if shed is open,, there is Facia/Flashing at top on sides and horizontal forces will cause moments in columns
4. Possibility of some partial height  from floor cladding / temporary / permanent  will transfer horz forces to columns.
5 Horz wind forces on ridge pieces will create moments in columns
Modelling shall reflect 3, 4 & 5 . Item 1&2 are taken care in truss modelling
