Hinges in Column
ramu_se
PostPosted: Mon Mar 11, 2024 1:08 pm    Post subject: Hinges in Column Reply with quote
How do we provide the detailing of the column if we add hinges in the column?
I have attached the image for your reference.
Thanks & Regards,
Ramu.
 Filesize:  6.13 KB
 Viewed:  37 Time(s)
PostPosted: Tue Mar 12, 2024 2:08 am    Post subject: Reply with quote
Er Ramu ji,,
Such a structural composition in portal frame seems hypothetical,  may be only academic and not practical.
Provision of Hinges :-
If steel column :- eg I section column
The hinge can be provided by making cut in each flange of  both portal columns and only web is continued. Still some minor moment will exist ( though Negligible) .
If Rcc columns :-
The detailing can be seen in any text book / literature. The column section is reduced at hinge to extent that it will be ok to pass vertical load/ horizontal force.The vertical bars of opposite faces are crossed at hinge and moment carrying capacity is almost zeroed.
Hinge connection is s provided st support points only ,, especially in steel columns . Portal action create double the moments at beam column junction reducing to zero moment at base (hinge pt)  versus fixed support connection.
spsvasan
PostPosted: Fri Mar 15, 2024 2:36 am    Post subject: Re: Hinges in Column Reply with quote
ramu_se wrote:
Thanks & Regards,
Ramu.
Dear Er.Ramu
You may refer RC  Designer's Handbook by Reynolds and Steedman
Table 182 (in 9th edition) shows detailing for Mesnager hinge and for Freyssinet hinge
S.P.Srinivasan
spsvasan
PostPosted: Fri Mar 15, 2024 11:29 am    Post subject: Re: Hinges in Column Reply with quote
spsvasan wrote:
ramu_se wrote:
Thanks & Regards,
Ramu.
Dear Er.Ramu
S.P.Srinivasan
Dear Er.Ramu
You may also refer Fig 11.25 and 11.26 of SP 34
S.P.Srinivasan
