Open STAAD
rahul.leslie
PostPosted: Fri Aug 30, 2024 6:52 am    Post subject: Open STAAD Reply with quote
Hi,
I have been trying to extract model details via OpenSTAAD, but it is showing error (Error 438)... The code is as below
Private Sub CommandButton1_Click()
    Dim openSTAADObj As Object
    Set openSTAADObj = GetObject(, "StaadPro.OpenSTAAD")
    openSTAADObj.OpenSTAADFile "D:\STD-Files\Str7.std"
    '==========================NODES===============================
    Dim nNodes As Long
    nNodes = openSTAADObj.Geometry.GetNodeCount
    Dim nodesList() As Long
    openSTAADObj.Geometry.GetNodeList nodesList()
    Dim xCoord As Double
    Dim yCoord As Double
    Dim zCoord As Double
    For i = 1 To nNodes
        openSTAADObj.Geometry.GetNodeCoordinates (nodesList(i - 1)), xCoord, yCoord, zCoord
        Worksheets("Sheet2").Range("A" & (i + 3)) = nodesList(i - 1)
        Worksheets("Sheet2").Range("B" & (i + 3)) = xCoord
        Worksheets("Sheet2").Range("C" & (i + 3)) = yCoord
        Worksheets("Sheet2").Range("D" & (i + 3)) = zCoord
    Next i
Set openSTAADObj = Nothing
End Sub
The line giving the error is shown highlighted above ... The function used is as documented:
anyboby, any idea what the problem is?
Rahul Leslie
 Filesize:  57.07 KB
 Viewed:  62 Time(s)
BVRAO
PostPosted: Sat Aug 31, 2024 5:34 am    Post subject: Reply with quote
I have developed many applications for  STAAD
I have not understand actually what  is your requirement
you have to declare  Excel also as an object
rahul.leslie
PostPosted: Sun Sep 01, 2024 3:29 pm    Post subject: Reply with quote
Thank you, sir, for your response.
This is a VBA program written within Excel, so Excel need not be made an object... the program is itself residing inside Excel
My only doubt is, whether the function...
...is working fine, in your experience. In my case, with the VBA code given in above post, it is giving error, saying:
Run-time error '5'
Invalid procedure call or argument
where could I be wrong?
Rahul Leslie
JVCSNL
PostPosted: Mon Sep 02, 2024 4:18 am    Post subject: Reply with quote
did you tried
openSTAADObj.Geometry.GetNodeList(nodesList)
Best Regards,
Jignesh Chokshi
rahul.leslie
PostPosted: Mon Sep 02, 2024 2:14 pm    Post subject: Reply with quote
..tried. It isn't working either.
BVRAO
PostPosted: Thu Sep 05, 2024 2:26 pm    Post subject: Reply with quote
who told   " openSTAADObj "  will be taken os an object in VBA
is there any examples you have
it is very easy   to read the TEXT file like  .STD    .TXT   . ANL in  VBA
and  load  the contents whatever you want .
Thats why am asking  what do you want to do
Definitely I will guide you         , I developed so many applications   long back      in excel VBA
JVCSNL
PostPosted: Fri Sep 06, 2024 4:12 am    Post subject: Open STAAD Reply with quote
Mr. Rao,
The OpenSTAADObj works well in VBA for sure.  It actually allow us to access the entire database rather than .std text file or .anl file having limited information.  It is better to use this object as it can be useful for updating the data within staad model itself through automation programs.
Dear Rahul,
The problem I see is that the nodelist is an array without defined dimension.
Since, we don't know how many nodes will be there in different models, it is necessary not to define its size in the first place.
Hence, we shall first define the variable without dimension (dim nodelist() as long  in this case).
Then, we shall count the nodes and then redimension the variable with exact size.
Try Below code:
Dim nNodes As Integer
ReDim nodesList(0 to (nNodes-1)) As Long
alternatively:
I think, these both approaches shall work:
Sharing another example, for support nodes from one of my programs.  Similar syntax.
Dim SupNode() As Long
Dim SC As Integer
SC = OST.Support.GetSupportCount
ReDim SupNode(0 To (SC - 1)) As Long
OST.Support.GetSupportNodes SupNode
Hope this works and your difficulty is solved.
Best Wishes,
Jignesh V Chokshi
rahul.leslie
PostPosted: Sat Sep 07, 2024 9:46 am    Post subject: Reply with quote
..wow, it worked 💪... thanks a lot, Jignesh sir 😊
I thought the GetNodeList function would re-dimension as well.
Rahul Leslie
BVRAO
PostPosted: Sun Sep 08, 2024 6:33 pm    Post subject: Re: Open STAAD Reply with quote
[quote="JVCSNL"]Mr. Rao,
Thanks a lot
without knowing above OpenSTAADObj
I have developed lot of code for STAAD
