nikhil.patelwsm General Sponsor
Posted: Tue Oct 15, 2024 4:35 am Post subject: INCLINED COLUMN DESIGN |
RESIDENTIAL BUILDING WITH G+5 FLOOR G AS STILIT PARKING ARCHITECT WANT COENER COLUMN TO BE SHFTED INSIDE BUILDING BY 1.2 M AND MAKE THEM INCLIEND AT 2.1M ABOVE PLINTH FOR CAR MOVEMENT , I HAVE ATTACH ARCH DWG AND SECTION IS IT POSSIBLE TO MAKE COLUMN INCLINED AT 2.1M I.E. (AT LINTEL LVL TO INCINED TILL FIRST FLOOR AND AFTER THAT FLOOR STAIGHT ) PLEASE GIVE US LOAD PATH IS IT POSSIBLE OR NOT
ELEVATION SUGGESTED BY ME FOR POSSIBILITY WANT TO KNOW CAN THIS BE FISSIBLE |
 Download |
Filename: |
SECTION OF COLUMN.pdf |
148.75 KB |
Downloaded: |
926 Time(s) |
 Download |
Filename: |
SECTION OF COLUMN R1.pdf |
148.72 KB |
Downloaded: |
895 Time(s) |
 Download |
Filename: |
TYPICAL FLOOR PLAN.pdf |
1.13 MB |
Downloaded: |
929 Time(s) |
 Download |
Filename: |
GROUND FLOOR PLAN.pdf |
1.12 MB |
Downloaded: |
889 Time(s) |
vikram.jeet General Sponsor
Posted: Wed Oct 16, 2024 3:32 am Post subject: |
Inclined column in this building arrangement shall be avoided as it may not provide a healthy structural system.
If Architect is very rigid,, he may be convinced,
Still Rigid :-
Eccentricity of system is never lost and upper storeys load on this column will be eccentric.
A) As regards vertical loads - these will be transferred to this column by twin actions :-
1) Through beam acting as cantilever beam
2) As Inclined member / corbel resisting vertical load tat tip through Thrust force ( much higher than vertical load based on taper angle) ,, PLUS Tensile force in the beam.
It will be wise that for such structural arrangement,, designer shall design 100% for each action.
B) Horizontal forces due to EQ
Transfer beam shall be heavy, to be designed for Moments,, Torsions,, But a x beam at tip of taper must exist tieing various columns and taking care of distribution of Eq forces
STILL I FEEL, NOT A GOOD STRUCTURAL ARRANGEMENT,, NEEDS TO BE AVOIDED IF POSSIBLE ,, SO THAT COLUMNS STRAIGHT( TRULY VERTICAL) WITH Cantilever Overhang OUTSIDE.
Posted: Wed Oct 16, 2024 3:36 am Post subject: |
FOR BETTER RESISTANCE TO EQ FORCES :-
Please keep Alternate columns truly vertical with Overhang outside,, so that EQ force is fully taken care by truly vertical column s..
I think Architect msy agree.
atul_123 ...
Posted: Mon Jan 20, 2025 9:59 am Post subject: Re: INCLINED COLUMN DESIGN |
nikhil.patelwsm wrote: | RESIDENTIAL BUILDING WITH G+5 FLOOR G AS STILIT PARKING ARCHITECT WANT COENER COLUMN TO BE SHFTED INSIDE BUILDING BY 1.2 M AND MAKE THEM INCLIEND AT 2.1M ABOVE PLINTH FOR CAR MOVEMENT , I HAVE ATTACH ARCH DWG AND SECTION IS IT POSSIBLE TO MAKE COLUMN INCLINED AT 2.1M I.E. (AT LINTEL LVL TO INCINED TILL FIRST FLOOR AND AFTER THAT FLOOR STAIGHT ) PLEASE GIVE US LOAD PATH IS IT POSSIBLE OR NOT |
Dear Nikhilji
kindly refer sketch provided for better understanding of load transfer.
80.58 KB |
Viewed: |
790 Time(s) |
