Steel Column Design over RCC Frame
Vijaykumarjethwa
PostPosted: Sat Nov 09, 2024 4:41 pm    Post subject: Steel Column Design over RCC Frame Reply with quote
Dear Friends
I tried to design a steel shed over RCC Columns in Staad Pro.However the problem with the file is the nodal displacement is very high.Also the steel columns are very heavy.Even ISMB550  is failing.I shall be thankful if you help me finding mistake in my Staad file which I have enclosed.I am sure I made some mistake but can't figure out.Guys please guide me.
Thanks & regards
Vijay Kr.Jethwa
Indoor_Hall_Editor.docx
 Filename:  Indoor_Hall_Editor.docx
 Filesize:  32.58 KB
 Downloaded:  1030 Time(s)
PostPosted: Fri Nov 15, 2024 11:07 pm    Post subject: Reply with quote
Steel column s shed over Rcc column structure
I think it is better to go for pipe columns ( round/ square) having L/R  same in two directions.
May be I section failing due to L/R in Lz dir.
If vertical bracing is provided at End/ penultimate bays,, the horizontal forces of wind can be easily negotiated by bracings and columns in minor direction I  yr case be spared of heavy moments.
Rcc column beneath can be taken as Fixed / Hinged connection as per detailing proposed at junction.
Vijaykumarjethwa
PostPosted: Tue Nov 19, 2024 4:23 pm    Post subject: Steel Column Design over RCC Frame Reply with quote
Thanks Vikram for your advise. I shall try to implement in my project and get back to you if I face any difficulty.
