yashrai SEFI Member
Posted: Wed Nov 27, 2024 6:33 am Post subject: Longitudinal forces in bearing level |
Dear all,
as per IRC 6, clause 211.5.1.1, horizontal force at bearing level is given as max. of Fh - μ (Rg +Rq) or Fh/2 + μ (Rg +Rq), where Rg and Rq are dead load and live load reactions at free end.
I have the case that on pier on which two simply supported spans rests one with fixed with free bearing and other with fixed bearing. I have calculated the live and dead load reaction on both of bearing.
Now my consfusion is as per the code do i have to use the reaction that comes on the free bearing only when calculating the horizontal force on fixed bearing?
Regards |
vikram.jeet General Sponsor
Posted: Wed Nov 27, 2024 4:11 pm Post subject: |
First of all let us think of one span
S S span
Deck Expanding -
Traffic moving from fixed to free bearing ,, Deck expanding
Fixed bearing force = B - T
Free Bearing Force = T
Deck Contracting
Traffic again moving from Fixed to free Bearing side
Fixed Bearing Force = B/2 +T
Free bearing = B/2 - T ( But not greater than T).
Now Two spans on pier having one span Fixed bearing (left on pier) and other span free bearing (Rt on pier) :
Traffic moving from left span to right span : Decks expanding
Left span Fixed bearng F = B/2 +T ( in direction of traffic)
Rt span free bearing force = B'/2 - T' ( in fir of traffic)
Hence force on pier additive of two
Traffic moving from Left to Rt, Dech Contracting :-
Left span fixed bearing force = B-T ( in traffic dur)
Rt span free bearing force = T' ( in traffic dir)
Both additives
B= Braking or other Horizontal force of Wind/ Eq
T = Temp movement,, frictional force ( = u(DL+Ll) )
B' T' for other deck
Just a view for thought on design |
