IS 1893-2023 DRAFT
alexsaji
PostPosted: Mon Jan 06, 2025 5:08 am    Post subject: IS 1893-2023 DRAFT Reply with quote
As per IS 1893-2023 draft -
The base shear force equation is found to be revised
In 2016 Code , Maximum Considered Earthquake (MCE) and Design Basis Earthquake (DBE) . Zone factor Z represents MCE and the Design Basis Earthquake is taken as 50% of MCE ie , Z/2 but as per draft Z/2 in the  current code is revised to Z
that is AHD =Z I ANH(T)/R
Where ANH(T) is the  Sa/g in current code.
Why is there such a drastic change from z/2 to Z in the new draft
atul_123
PostPosted: Mon Jan 20, 2025 7:10 am    Post subject: Reply with quote
Dear Sefian
Kindly go through the file attached here
"Impact of Draft IS 1893-2023 Code Provisions on Building Design"
it might give some clear idea.
Dr.SubramanianEr.LeslieArticle-October23.pdf
 Filename:  Dr.SubramanianEr.LeslieArticle-October23.pdf
 Filesize:  3 MB
 Downloaded:  110 Time(s)
