admin Site Admin
Joined: 21 Feb 2008 Posts: 692 Location: Phoenix Webtech Pvt. Ltd. Mumbai [
Posted: Wed Mar 19, 2025 7:59 am Post subject: An Appeal- REVISION of National Building Code of India (NBC) -DRAFT Chapters issued in Wide Circulation - for commenting |
Dear All
BIS is revising its National Building Code of India 2016 (NBC 2016). The following chapters relating to Structural Design are open for review and commenting:
- Structural Design - Loads, Forces & Effects
- Structural Design - Soils & Foundation
- Structural Design - Steel-Concrete Composite Construction
- Structural Design - Glass & Glazing
- Structural Design using Timber
- Structural Design using Bamboo
To access the above 6 chapters (and 4 more to be uploaded), please visit this SEFI post and process to send comments
https://www.sefindia.org/forum/viewtopic.php?t=21245
Download MS Word document format for sending comments: Click here
Additionally 3 options exist to access above 6 chapters:
Option 1 - Follow the static weblink of BIS: https://www.services.bis.gov.in/php/BIS_2.0/dgdashboard/draft/wc_draftcommitteeDetails/63
Option 2 - Follow the LinkedIn page of BIS: https://www.linkedin.com/company/105614273/admin/page-posts/published/
Option 3 - Follow the WhatsApp Channel of BIS: https://whatsapp.com/channel/0029VaKdgv3GzzKM6SCoDS0c
Please reply to us with your comments in DOC format only to CED46@BIS.GOV.IN id which is specific to NBC Works.
Thanks and regards,
Arunkumar S
BIS
 Download |
Filename: |
Format for Sending Comments.docx |
22.32 KB |
Downloaded: |
98 Time(s) |
vikram.jeet General Sponsor
Posted: Fri Mar 21, 2025 6:32 am Post subject: |
Loads and Forces : Wind Loads
Clause 4.5.2.2 Table 7
REDUCTION FACTOR FOR FLEXIBLE CLAD STRUCTURES NEEDS TO BE GIVEN FOR TENT, TARPOLINE CLADDINGS
Posted: Fri Mar 21, 2025 6:57 am Post subject: |
LOADS AND FORCES
SECTION - SOULS AND FOUNDATIONS
Annexure J - TABLE GIVING UNDER-REAMED PILE CARRYING CAPACITIES ( BOTH VERTICAL AND LATERAL) BASED ON PILE DIA - AS ALREADY THERE IN BIS CODE EARLIER VERSIONS,
This is requested to be retained
ADDITIONAL ANNEXURE -
A TABLE GIVING PRELIMINARY ESTIMATE OF SAFE BEARING CAPACITIES OF SOILS FOR GENERAL BUILDINGS LESS THAN TWO STOREYS - AS ALREADY PROVIDED IN NBC OLD VERSION BEFORE 2000 .
THIS IS NEEDED VERY MUCH FIR SMALL BUILDING STRUCTURES
Posted: Sat Apr 19, 2025 6:12 am Post subject: |
AN IS CODE REQUIRED IN MODELLING OF STRUCTURES PROVIDING GUIDELINES FOR IDEAL STRUCTURES MODELLING,
SINCE COMPUTER SOFTWARE AGE,,
INCORRECT MODELLING MAY LEAD TO INACCURATE RESULTS AND HENCE GUIDELINES ON MODELLING ASPECTS NEEDS TO BE COVERED.
JUST A SUGGESTION FOR CONSIDERATIONS
