francis chacko General Sponsor
Posted: Mon May 09, 2011 7:48 am Post subject: qualification required for structural design |
DEAR MEMBERS
I AM ATTACHING A COPY OF GOVT.OF KERALA LETTER NO.GO (MS) NO. 41/11/LSGD DATED 14.02.2011.
AS PER RULE 115 HIGH RISE BUILDING (HEIGHT EXCEEDING 15 METRES ) IS TO BE DESIGNED BY POST GRADUATE ENGINEERS (AN EXTRACT IS ALSO ATTACHED FOR READY REFERENCE).
THIS RESTRICTION FOR GRADUATE ENGINEERS WAS NOT THERE PREVIOUSLY.
IN MANY OF THE GOVT.DEPARTMENTS AND PRIVATE CONSULTANT OFFICES GRADUATE ENGINEERS ARE UNDERTAKING STRUCTURAL DESIGNS
MANY GRADUATE ENGINEERS ARE PRACTICING AS STRUCTURAL ENGINEERS INDEPENDENTLY.
MANY GRADUATE ENGINEERS HAVE DONE STRUCTURAL DESIGN WORKS IN THE NATION BUILDING FROM VERY BEGINING
HENCE I WOULD LIKE TO HAVE COMMENTS/DISCUSSION/APPROPRIATE ACTION REQUIRED IN THE SUBJECT MATTER
W.BEST WISHES,
K C FRANCIS
BUILDING RULE 115.doc |
22.5 KB |
1697 Time(s) |
KERALA GOVT.BUILDING RULE |
go20110214_7056.pdf |
378.97 KB |
5755 Time(s) |
yacub SEFI Regulars
Posted: Sun May 15, 2011 4:09 pm Post subject: Qualification of structural engineers |
Sir
Kerala falls in Zone III of Earth quake. National disaster Management Authority (NDMA) has issued special guidlines for the design & construction of buildings & structures in Zone III, IV & V. NDMA has prepared "Model Building rules" to be followed in Zone III, IV & V.
As per this Model building rules, the qualification of Registered Structural engineers (RSE) is fixed as Post graduation in Structural engineering. Buildings less than 3 stories can be designed by any Civil engineer, where as, buildings higher than 3 stories is to be designed by a Post graduate in Structural engineer. Building higher than 7 stories is to be proof checked by another Structural engineer.
Kerala never used to have buildings higher than 4 stories in earlier days. Post graduate structural Engineers were also very few. The building done in older days had very high factor of safety and hence those building were not cost effective. Framed structures were not used for these buildings.
Now, Kerala has buildings higher than 40 stories. The safety of the inhabitants of these high rise buildings is of great concern to the govt. Hence Kerala govt has insisted that the buildings higher than 15 m is to be designed by a specilist in Structural Engineering. All life line structures like hospitals, theaters, TV towers are to be designed by RSE
We go to eye specilist for eye decises, urolosist for kidney disorders, Heart specialist for heart problems. A chartered Accountant is required to certify balance sheets. There are Management specilists like - finance, HR, etc.
Civil Engineerig is not just Structural engineering. Bridge Engineers, high way engineers, construction engineers, irrigation engineers, railway, airport, ports and so on require the services of Specilaists in Civil Engineers. Enviornmental engineers and Transportation engineers are in great demand these days.
Leave the structural design is specialists in Structural Engineering. I subscribe to the views of Kerala government, NDMA & NBC in this regard.
Dr. Yacub Mohan George
Posted: Mon May 16, 2011 5:52 am Post subject: QUALIFICATION FOR STRUCTURAL DESIGN |
DEAR DR.YACUB MOHAN GEORGE,
I REGRET THAT I CAN NOT ACCEPT YOUR VIEW.
THE PRESENT RULE SERVES MANY GRADUATE ENGINEERS WHO ARE PRACTICING WITH JOBLESS.
ESPECIALLY GRADUATES WITH MORE THAN 30 YEARS ARE PRACTICING.IT IS AN UNJUST DECISION,
YOU MAY COMPARE OTHER STATES.THE UNDER SIGNED HAD WORKED AS STRUCTURAL ENGINEER IN MUM BAY AND HAD DONE DESIGN OF MANY MULTISTORY BUILDINGS.
YOUR CONTENTION THAT THE DESIGN OF GRADUATE ENGINEERS WILL BE UNECONOMICAL IS NOT AGREED TO AS DESIGN METHODOLOGY IS SAME FOR GRADUATE ENGINEER OR POST GRDAUATE ENGINEER.A SENIOR GRADUATE ENGINEER MAY EVEN DO ECONOMICAL DESIGN BASED ON HIS EXPERIENCE.
YOUR COMPARISON WITH OTHER SPECIALIST DOCTORS IS ALSO NOT AGREED TO.
EVEN A PHYSICIAN OR MBBS DOCTOR ALSO TREATS FOR ALL.THERE IS NO BAN THAT PHYSICIAN OR MBBS DOCTOR SHOULD NOT TREAT FOR EYE DISEASE ETC.
MORE OVER A POST GRADUATE ENGINEER DIRECT FROM HIS STUDIES ALSO COULD NOT DESIGN PROPERLY.HE NEEDS AT LEAST TWO YEARS EXPERIENCE TO WORK IN A CONSULTANT ORGANIZATION OR UNDER SENIORS IN GOVERNMENT DEPARTMENT.
HENCE THERE SHOULD NOT BE SUCH AMENDMENT.LEAVE THE RULE AS IT WAS.
LET THE CLIENT CHOOSE HIS STRUCTURAL DESIGNER.
AS INTIMATED BY ME PLEASE NOT THAT MANY GRADUATE ENGINEERS HAD CONTRIBUTED IN THE NATION BUILDING MUCH BEFORE TO EVEN YOUR BIRTH.
HENCE PLEASE DO NOT DISREGARD SENIOR GRADUATE ENGINEERS.
KINDLY TAKE AN INITIATIVE TO REGULARIZE AS IN THE PAST
WITH B.WISHES,
K C FRANCIS
srini66 SEFI Member
Posted: Mon May 16, 2011 6:16 am Post subject: Re: QUALIFICATION FOR STRUCTURAL DESIGN |
I STRONGLY AGREE WITH Mr. K.C FRANCIS. THERE ARE SO MANY INSTANCES OF SOLVING ENG. PROBLEMS BY LESS KNOWN PEOPLE.
REGARDS
K.L SRINIVAS
francis chacko wrote: | DEAR DR.YACUB MOHAN GEORGE,
WITH B.WISHES,
K C FRANCIS |
Posted: Mon May 16, 2011 6:20 am Post subject: qualification for structural engineers |
DEAR MR.SREENIVAS,
THANK YOU VERY MUCH FOR YOUR SUPPORT
K C FRANCIS
Madan Lal Bairwa SEFI Member
Posted: Mon May 16, 2011 11:02 am Post subject: can this rule follows in all india? |
dear ur suggestion about this rule about specialisation i m agree but this rule must be in all india,,,,here in rajasthan thare is not more known people about structure engineers.........an architect can give high rise buildings structural design..no one objection for this............
Posted: Mon May 16, 2011 11:37 am Post subject: QUALIFICATION OF STRUCTURAL ENGINEERS |
THANK YOU ER.MADAN LAL MINT.PL.DISCUSS WITH YOUR COLLEAGUES AND REPRESENT THE MATTERS TO THE CENTRAL GOVT./STATE GOVT. TO RECTIFY
THE RULES
B.WISHES,
K C FRANCIS
Posted: Mon May 16, 2011 12:19 pm Post subject: qualification required for structural design |
Experience is not taught but is caught. Ignorance of Experienced may
backfire.
Respected Er Sh UH Varyani sahab who has qualification of Degree in Civil Engg
has trained many M tech and even Ph D engineers who had chance to meet
him during his working years.
One has to be a practitioner for the subject. Higher Qualification is definitely an
added advantage but Qualification alone without experience /aptitude may not
serve any purpose.
Govt of Kerala may be requested to honour the experience of B tech's who served the
structural engg profession for long (upto late eighties Mtech were few).
Mtech qualification may be made mandatory for fresh design Ers since output of Mteh
is quite substantial at present times.
Ignorance of experienced is not a wise step.
with due regards to Er KC Francis for his long standing experience of structural
designing
vikramjeet
REGARDS
K.L SRINIVAS
-- ญญ
venkatesh General Sponsor
Posted: Tue May 17, 2011 4:46 am Post subject: |
Knowledge depends upon the person irrespective of the qualification. Even those persons who are having Ph.D's and some times may not design a simple building practically. certanly for wise persons and those who are curious to learn the things the qualification as well as experience will be added an advantage. qualification will boost the self confidence and it also works enhancing the self esteem before the clients.
venkatesh
MANOJ MITTAL ...
Posted: Tue May 17, 2011 5:28 am Post subject: qualification required for structural design |
Dear Friends,
Structural engineering is part of Civil engineering . No doubt higher qualifications such as PG and doctorate will be desirable for structural engineering practice but it can not be mandatory requirement. Even higher qualifications without relevant experience has no meaning. Similarly Graduation in Civil engineering with relevant experience may be sufficient for structural engineering practice. In my views relevant experience and aptitude for designing is essential for our profession. Continueous upgradation of knowledge by way of self study, short term courses, seminars, workshops etc are also very important.
Qualifications and competence mentioned in NBC-2005 and Model bye-laws issued by NDMA (Min. of Home affairs ) and membership requirements for IAStructE are also based on this principle . Minimum 5-7 years of relevant experience is essential for independent practice. Making PG mandatory requirement and barring Graduate engineers (with relevant experience) will not be conducive for the profession . Kerala government should be asked to modify the bye-laws.
best regards,
MANOJ MITTAL
To: general@sefindia.org
Sent: Mon, 16 May, 2011 6:10:09 PM
Subject: [SEFI] Re: qualification required for structural design
backfire.
serve any purpose.
designing
vikramjeet
REGARDS
K.L SRINIVAS
-- ญญ
