p_kadam at vsnl.com Guest
Posted: Thu Jul 21, 2005 11:33 am Post subject: Fe 550 |
Dear all,
Refer Article Steel-Reinforcement by Dr P C Basu et al.
"Cautious approach" is advised while using Fe 550. It has not been ruled out.
regards,
P Kadam
Mr Joshi wrote
> > The high yield strength steel produces higher factored shears and they > have to be carried by the beam without exceeding the maximum shear > stress Tcmax given in Table 20 of I.S. 456 : 2000 even though shear > reinforcement is provided. Therefore, higher concrete sections > will be > > > Dear Mr. Kadam, > > The high yield strength steel produces higher factored shears and they > have to be carried by the beam without exceeding the maximum shear > stress Tcmax given in Table 20 of I.S. 456 : 2000 even though shear > reinforcement is provided. Therefore, higher concrete sections > will be > required for beams to resist shears produced during earthquake episode > and it has futhther implications on the stiffness of the frame that > has additional adverse effect on the force distribution and will > attrect higher earthquake forces > > This means the proposed steel having high yield strength such as Fe > 600 is not welcome and if you look at New Zealand code AS/NZS > 4671-2001, they have only Fe 300E and Fe500E category steel. > > Neelkanth D Joshi > Joshi Consultants > joshiconsultants9@gmail.com > > > > > The views, opinions, analyses and assessments contained herein do > not necessarily reflect the views of SEFI or TATA Steel. Also SEFI > and TATA Steel does not guarantee the accuracy of the data > included in the proceedings of this e-conference and accepts no > responsibility for any consequences of their use. > ******************************************* > ========powered by Reach1to1 Office Everywhere
