m_sawai General Sponsor
Posted: Sat Nov 09, 2013 7:55 am Post subject: |
Attached spreadsheet is meant for checking of rectangular r c columns under compression/tension and biaxial bending for upto 24 load cases.
It is intended for study or checking rather than routine design in a design office.
MS
 Download |
Filename: |
(P0)R C Columns-Rectangular-Biaxial bending-Section design-IS456.xls |
633.5 KB |
Downloaded: |
13220 Time(s) |
Posted: Sat Nov 09, 2013 8:00 am Post subject: |
Attached spreadsheet is meant for checking or rectangular r c columns
under compression/tension and biaxial bending with capacity design under seismic conditions included.
MS
 Download |
Filename: |
(P0)R C Columns-Rectangular-Biaxial bending-Member design-IS456+IS13920.xls |
968 KB |
Downloaded: |
8327 Time(s) |
naga ...
Posted: Sat Nov 09, 2013 11:00 am Post subject: RCC COLUMN DESIGN |
SIR,
SEND ME RCC COLUMN DESIGN FOR AXIAL LOAD AND BIOAXIAL MOMENT SPREAD SHEET.
MAIL.ID: mani.malli@rediffmail.com
hiteshcparmar wrote: | yes friends
i have that spreadsheet
give me your email id i will post it to you |
sknsrinivasan ...
Posted: Mon Nov 11, 2013 4:41 am Post subject: |
Dear m_sawai
Tne excel sheet which you have sent protected by password plz send the password to my mail Id sknsrinivasan@gmail.com
N.Srinivasan
sharathkumar2k6 SEFI Member
Posted: Sun Oct 18, 2015 6:34 pm Post subject: Excel Sheets |
Hello All
Can anybody give me excel sheets for design of beam columns , slab using Indian Code. It will help me a lot...
Thankyou
rajancivildesign@gmail.co ...
Posted: Mon Oct 19, 2015 3:09 am Post subject: RCC Design Excell sheet |
Please find one attachment on RCC Excell sheet already available in SEFI.
V.M.RAJAN
 Download |
Filename: |
RCC_Design.rar |
279.95 KB |
Downloaded: |
8542 Time(s) |
Posted: Mon Oct 19, 2015 1:24 pm Post subject: |
Thank you sir for those excel sheets.
Sharath
knsheth123 Silver Sponsor
Posted: Tue Oct 20, 2015 1:26 pm Post subject: RCC column with Axial Load and Biaxial moment (As per IS:456 |
Pl. find the Worksheet for Design of RCC Rectangular Column subjected axial load with Biaxial Bending.
It is already uploaded on SEFI before few months.
It is very simple to use and uses Macro functions in Excel developed by my son Rutvik Sheth.
With Warm Regards
K. N. Sheth
Dharmsinh Desai University, Nadiad.
 Download |
Filename: |
First_Col_Dsn_fina_RCC-Biaxial-Bending.xls |
251 KB |
Downloaded: |
5443 Time(s) |
Posted: Thu Oct 22, 2015 2:44 pm Post subject: RCC column with Axial Load and Biaxial moment (As per IS:456 |
Dear All
Pl. find the RCC Rectangular Column Design Excel Worksheet with Updates :
1. It calculates approx. percentage steel required to satisfy all given load combination to assist selecting rebar details
2. It incorporates Fe 415 and Fe 500 grade steel
3. Fck upto M60 considered.
The worksheet is protected without password, Macros are also kept open.
As this worksheet is used by PG structures faculty & students at no. of Institutes.
Pl. keep it protected while using so that the equations remains unaltered.
With warm regards
K. N. Sheth
 Download |
Filename: |
First_Col_Dsn_22-10-2015.xls |
261 KB |
Downloaded: |
4380 Time(s) |
aslam SEFI Member
Posted: Fri Oct 23, 2015 9:02 am Post subject: DESIGN OF RCC COLUMN |
Dear Sheth Sir,
The spread sheet you have provided doesn't allow option to provide laterally unsupported length for column in-order to calculate moment due to minimum eccentricity.
Please find attached file
 Download |
Filename: |
Column Design.pdf |
530.04 KB |
Downloaded: |
5434 Time(s) |
