SHEAR DESIGN BEAM,COLUMN,JOINT IS-13920
HEMAL MISTRY
PostPosted: Tue Jun 24, 2008 4:09 am    Post subject: SHEAR DESIGN BEAM,COLUMN,JOINT IS-13920 Reply with quote
Hello all!
Plz find here as attachment spreadsheet for shear design of Beam, Column and Beam-Column Junction (Joint) as per IS-13920 (Draft). Plz check, and correct if any error left.
Hemal Mistry
Surat
SHEAR_DESIGN_BEAM__COLUMN___JOINT_IS-13920_DRAFT.zip
 Filename:  SHEAR_DESIGN_BEAM__COLUMN___JOINT_IS-13920_DRAFT.zip
 Filesize:  45.79 KB
 Downloaded:  872 Time(s)
Noor ul haq
PostPosted: Mon Sep 11, 2017 9:28 am    Post subject: Thank you Reply with quote
Thank you  sir
