Modeling,analysis and design of FLAT SLAB bldg. using STAAD
PrachiThube
PostPosted: Mon Jan 05, 2009 10:19 am    Post subject: Modeling,analysis and design of FLAT SLAB bldg. using STAAD Reply with quote
Dear All
         I have tried to model the flat slab building for analysis for lateral loading (model valid only for column and shear wall design) on my own in absence of any more information.
       I will like if experts in STAAD gives me any comments, correction on this. Once model is complete I will upload another model with loads applied and analyzed as per method suggested by Mr. Vipul Sir.
       As it is imaginary building experts can suggest me any changes so that this will be close to reality.
       I hope by the end of the E-Conference after incorporating comments from experts this STAAD file will become an ideal reference file for all.
P Thube
flate slab.zip
 Filename:  flate slab.zip
 Filesize:  62.37 KB
 Downloaded:  3216 Time(s)
pandharkarnitin
PostPosted: Mon Jan 05, 2009 11:01 am    Post subject: Modeling,analysis and design of FLAT SLAB bldg. using STAAD Reply with quote
Hi
This is Nitin
I ha one confusion regarding model
Why did u given cross members in slab ?
Thanking You
Nitin
Sent: Monday, January 05, 2009 3:49 PM
To: econf@sefindia.org
Subject: [ECONF] Modeling,analysis and design of FLAT SLAB bldg. using STAAD
Dear All
P Thube
flate slab.zip
This e-mail and any attachment are confidential and may be privileged or otherwise protected from disclosure. It is solely intended for the person(s) named above. If you are not the intended recipient, any reading, use, disclosure, copying or distribution of all or parts of this e-mail or associated attachments is strictly prohibited. If you are not an intended recipient, please notify the sender immediately by replying to this message or by telephone and delete this e-mail and any attachments permanently from your system.
ajayapc
PostPosted: Mon Jan 05, 2009 11:22 am    Post subject: Flat slab modelling Reply with quote
Dear Er Thube
I have seen your modelling.  I think you should create additional one node in each panel so that overlapping of diagonal flab elements can be modelled close to reality.
Let us also seek comments/suggestions from other sefians.
BYE
AJAY CHOURASIA
pathre_v
PostPosted: Mon Jan 05, 2009 11:55 am    Post subject: Modeling,analysis and design of FLAT SLAB bldg. using STAAD Reply with quote
The model in staad does not show flat slab. you have to model flat slab as finite element. Why have you provided cross beams and connecting beams ? Remove cross beams and connecting beams in plan and model as elements connecting four columns.
vijay
Date: Monday, 5 January, 2009, 3:49 PM
Dear All
P Thube
flate slab.zip
Add more friends to your messenger and enjoy! Invite them now.
PrachiThube
PostPosted: Mon Jan 05, 2009 12:48 pm    Post subject: Re: Modeling,analysis and design of FLAT SLAB bldg. using ST Reply with quote
Just to simulate rigid diaphragm action.
Please see vipul sirís paper. As per that procedure we have to assign pin support to each column(in order to take 100% base shear by shear wall).
Master slave commends doesnít work in this case.
I will like to know from experts what properties one should use for this member.
Thanks !
P Thube
pandharkarnitin wrote:
Hi
This is Nitin
Thanking You
Nitin
Dear All
P Thube
flate slab.zip
pathre_v
PostPosted: Mon Jan 05, 2009 7:03 pm    Post subject: Modeling,analysis and design of FLAT SLAB bldg. using STAAD Reply with quote
I have done some rectifications in the model by deleting beams and adding plate elements as flat slab. I have release moments in the columns in order to transfer the horizontal forces to shear wall. please comment whether the procedure is correct.Pl refer to the attached file
vijay
Dear All
P Thube
flate slab.zip
Be the first one to try the new Messenger 9 Beta! Click here.
pathre_v
PostPosted: Mon Jan 05, 2009 7:09 pm    Post subject: Modeling,analysis and design of FLAT SLAB bldg. using STAAD Reply with quote
please download the attachment
Vijay
Dear All
P Thube
flate slab.zip
PrachiThube
PostPosted: Tue Jan 06, 2009 6:13 am    Post subject: Modeling,analysis and design of FLAT SLAB bldg. using STAAD Reply with quote
where is the attachement?
P. Thube
pathre_v
PostPosted: Tue Jan 06, 2009 4:27 pm    Post subject: Re: Modeling,analysis and design of FLAT SLAB bldg. using ST Reply with quote
[/img][/code]
file attached
MODEL1.ed.zip
 Filename:  MODEL1.ed.zip
 Filesize:  7.16 KB
 Downloaded:  2158 Time(s)
rahul.leslie
PostPosted: Fri Jan 09, 2009 6:32 am    Post subject: Reply with quote
I think you have released all column ends on a structure that has no shear walls...
