Welding Anchor Bolts
Goto page 1, 2, 3  Next
jatfuentes
PostPosted: Wed Jan 07, 2009 11:23 am    Post subject: Welding Anchor Bolts Reply with quote
We have a problem in our company. The constructor made a mistake with the projection length over the concrete
of the anchor bolts in a big foundation. The length of the bolts are short of necessary, and now they want to
weld a piece of bolt in order to get the right length. The Anchor bolts have a diameter of 2" and the material
is SAE 1020.
Any of you have experience with this problem?. I will like to hear your experiences or ideas.
Any advice will be welcome.
With regars,
Jatfuentes
Thankful People
PostPosted: Wed Jan 07, 2009 2:55 pm    Post subject: Welding Anchor Bolts Reply with quote
Hi Jatfuentes,
These kinds of problems often arise in construction. Once I was shocked to find a contractor using gas torches for enlarging the holes, as the drilled holes did not match at the site! If the forces applied on the base plate are Compressive, no problem in increasing the length by welding. But if they are Tensile, you have to take precautions.
Maryland, USA
--- On Wed, 1/7/09, jatfuentes <forum@sefindia.org> wrote:
Subject: [SEFI] Welding Anchor Bolts
Date: Wednesday, January 7, 2009, 5:30 PM
is SAE 1020.
With regars,
Jatfuentes
jatfuentes
PostPosted: Wed Jan 07, 2009 3:56 pm    Post subject: Welding Anchor Bolts Reply with quote
Thank you Dr Subramanian,
Your advice make to much sense, because theoretically anchor bolts are necessary only for uplift forces. I will
check with the engineer if there is uplift in his structure or if these anchor bolts are compressed.
Again,
---------- Cabeçalho original -----------
De: "drnsmani" forum@sefindia.org
Para: general@sefindia.org
Cópia:
Data: Wed, 07 Jan 2009 20:56:15 +0530
Assunto: [SEFI] Re: Welding Anchor Bolts
Hi Jatfuentes,
[Image: http://us.i1.yimg.com/us.yimg.com/i/mesg/tsmileys2/23.gif ]Dr.N.Subramanian,Ph.D.,F.ASCE, M.ACI,
Maryland, USA
(http://www.multi-science.co.uk/subramanian-book.htm)
www.oup.co.in/search_detail.php?id=144559 (http://www.oup.co.in/search_detail.php?id=144559)
is SAE 1020.
With regars,
Jatfuentes
anurag.sinha
PostPosted: Thu Jan 08, 2009 2:47 am    Post subject: Welding Anchor Bolts Reply with quote
Dear Jatfuentes
In addition to tension (case specific) there has to be some shear force also (wind/ seismic). Therefore my advise would be to check for combined forces, which is more critical.
Anurag Sinha
Sent: 07 January 2009 21:59
Subject: [SEFI] Re: Welding Anchor Bolts
Again,
De: "drnsmani" forum@sefindia.org (forum@sefindia.org)
Para: general@sefindia.org (general@sefindia.org)
Cópia:
PostPosted: Thu Jan 08, 2009 4:02 am    Post subject: Welding Anchor Bolts Reply with quote
Dear  Mr Jatfuentes
I think by Butt- welding the piece of anchorbolt with already embeded
AnchorBolt , you may not achieve the desired tensile strength
In addition to this, it will be more effective if the embeded Anchor bolts
shall be Fillet-welded with the base plate after its positioning (at site)
to provide additional strength against tensile forces due to uplift
vikramjeet
ibarua
PostPosted: Thu Jan 08, 2009 4:50 am    Post subject: Welding Anchor Bolts Reply with quote
9TH JAN 2009
In case of tensile forces on the bolts, a solution may be to provide a 'cover' or 'sleeve' over the butt welded joint and then weld the 'sleeve' to the bolt, taking care not to damage the threads which will hold the nuts in place. Also, the question of loss of strength /increase in brittleness of the bolts due to heating during the welding process has to be considered.
Indrajit Barua.
On Wed, 07 Jan 2009 drnsmani wrote :
Hi Jatfuentes,
[Image: http://us.i1.yimg.com/us.yimg.com/i/mesg/tsmiley-
Maryland, USA
See my books at: www.multi-science.co.uk/subramanian-boo-
k.htm (http://www.multi-science.co.uk/subramanian-book.h-
tm)
concrete
to
material
is SAE 1020.
With regars,
Jatfuentes
PostPosted: Thu Jan 08, 2009 3:24 pm    Post subject: Welding Anchor Bolts Reply with quote
Dear Mr.Jatfuentes,
The following solution suggested by Mr.Indrajit Barua is the best one for you to adopt, whether the anchor bolt is in tension or compression.
Maryland, USA
--- On Thu, 1/8/09, ibarua <forum@sefindia.org> wrote:
[quote]From: ibarua <forum@sefindia.org>
Date: Thursday, January 8, 2009, 10:32 AM
9TH JAN 2009
Indrajit Barua.
jatfuentes
PostPosted: Thu Jan 08, 2009 6:37 pm    Post subject: Welding Anchor Bolts Reply with quote
Thanks, Dr. Subramanian, Thanks Mr. Indrajit Barua and all friends that sent ideas,
It is exactly what a I did. I used a butt weld and a sleeve welded to the anchor bolt. The pipe (sleeve ) I
used is SAC 50, of better quality than the anchor bolt( SAE 1020).
In other e-mail I will send the detail of the anchor bolt splice for future reference.
jatfuentes
Cópia:
Data: Thu, 08 Jan 2009 21:34:02 +0530
Dear Mr.Jatfuentes,
Maryland, USA
9TH JAN 2009
Indrajit Barua.
pravin.pai
PostPosted: Fri Jan 09, 2009 1:05 pm    Post subject: Welding Anchor Bolts Reply with quote
Dear Mr Barua:
I did not understand this solution. After he provides the sleeve over the joint, how can they screw the nut over it?
ppai
On 1/8/09, ibarua <forum@sefindia.org (forum@sefindia.org)> wrote: [quote]  9TH JAN 2009
Indrajit Barua.
ranna
PostPosted: Sat Jan 10, 2009 5:35 am    Post subject: Welding Anchor Bolts Reply with quote
the anchor bolt can definitely be welded.
for welding requirement kindly contact
welding research institute
bhel,
trichy 620014
phone 0431 2520266
r.anna
ranna@bheltry.co.in (ranna@bheltry.co.in)
jatfuentes wrote:
is SAE 1020.
With regars,
Jatfuentes
Page 1 of 3
