P.K.Mallick General Sponsor
Joined: 14 Dec 2008 Posts: 1098 Location: Kanpur. p.k.mallick1962@gmail.com
Posted: Mon Feb 09, 2009 2:32 am Post subject: VERTICAL EXTENSION OF OLD BUILDING. |
The building is G+3(Ground +3 upper floors). It was constructed sometimes in early Eighty. Structural Drawings are not available. There were dowels left in columns for vertical extension. Dowels left for vertical extension appear to be adequate for extension of one more floor. Since structural drawings are not available, theoretically it cannot be determined whether foundations have been designed for G+3 (Ground +3 upper floors) or G+4(Ground +4 upper floors).
Is there any way out? How to determine whether vertical extension is possible or not? _________________ P.K.Mallick
sakumar79 ...
Posted: Mon Feb 09, 2009 8:12 am Post subject: |
Perhaps footings can be exposed at a few locations (only peripheral columns will be feasible) to estimate load capacity and a rough estimate can be made to check if load with the extra floor is within limits... If this is reasonable at a few locations, it may be proceeded with an extra floor...
Otherwise, you can think of going for Truss roof with Aerocon blocks to reduce the extra load on the footings.
Arun |
ibarua General Sponsor
Posted: Mon Feb 09, 2009 1:09 pm Post subject: VERTICAL EXTENSION OF OLD BUILDING. |
9th Feb 2009
Re.: Vertical extension of old building
No way to determine soundness of design and construction without proper records, except to go in for expensive and time consuming non-destructive testing.
Best to leave such old "unengineered" (without any drawings and /or records of construction)structures alone.
Indrajit Barua.
On Mon, 09 Feb 2009 P.K.Mallick wrote :
Quote: | The building is G+3(Ground +3 upper floors). It was constructed sometimes in early Eighty. Structural Drawings are not available. There were dowels left in columns for vertical extension. Dowels left for vertical extension appear to be adequate for extension of one more floor. Since structural drawings are not available, theoretically it cannot be determined whether foundations have been designed for G+3 (Ground +3 upper floors) or G+4(Ground +4 upper floors). Is there any way out? How to determine whether vertical extension is possible or not?
------------------------ P.K.Mallick munamallick@yahoo.co.in mallick.pravatkumar@gmail.com http://360.yahoo.com/munamallick
mks ...
Joined: 27 Dec 2008 Posts: 82 Location: Patna: email mks.b08@gmail.com
Posted: Mon Feb 09, 2009 1:22 pm Post subject: |
Les us assume after exposing the footing, if it is observed that , pile foundation is adopted. in that case what will be the solution.
Mithilesh
sakumar79 wrote: | Perhaps footings can be exposed at a few locations (only peripheral columns will be feasible) to estimate load capacity and a rough estimate can be made to check if load with the extra floor is within limits... If this is reasonable at a few locations, it may be proceeded with an extra floor...
Arun |
chandra SEFI Member
Posted: Mon Feb 09, 2009 6:39 pm Post subject: VERTICAL EXTENSION OF OLD BUILDING. |
A thoughtful and proper assessment I think is the first step. Not forgetting that the building’s almost 30 years old i.e. it’s through its half life. Costlier and detailed assessment will give closer results. Please assume greater responsibility if this is a hospital or a school building, or some very important facility.
Chandra
Sent: 09 February 2009 18:49
Subject: [SEFI] Re: VERTICAL EXTENSION OF OLD BUILDING.
9th Feb 2009
Indrajit Barua.
sakumar79 ...
Posted: Tue Feb 10, 2009 1:37 am Post subject: |
As I mentioned, if it is not feasible to verify foundation capacity you can go for aerocon blocks with truss roof... This will not overload the structure too much even if it has been designed for G+3 only.
Arun |
Posted: Tue Feb 10, 2009 2:42 am Post subject: |
My question is "whether there is any scientific way to assess the load carrying capacity of foundations of an old building". Any methodology explained in any of the publications? Whether somebody has carried out this type of work? If yes,then how it has been assessed? _________________ P.K.Mallick
pravin.pai General Sponsor
Posted: Tue Feb 10, 2009 4:21 am Post subject: VERTICAL EXTENSION OF OLD BUILDING. |
Dear Mr Mallick:
As a good CE, it is not advisable to go in for extra loading, 'blind-folded'. Remember a Bandra (East) building collapse some years ago wherein a Str.Engr. of reputed stature had added 3 more floors to a building also previously designed by him.
Moreover, if this project of yours is in Mumbai, remember underground drainage leakages deteriorates the foundations more than the super structure.
So without earlier str.dwgs. do not risk additional load
pravin pai
On 2/9/09, P.K.Mallick <forum@sefindia.org (forum@sefindia.org)> wrote: Quote: | The building is G+3(Ground +3 upper floors). It was constructed sometimes in early Eighty. Structural Drawings are not available. There were dowels left in columns for vertical extension. Dowels left for vertical extension appear to be adequate for extension of one more floor. Since structural drawings are not available, theoretically it cannot be determined whether foundations have been designed for G+3 (Ground +3 upper floors) or G+4(Ground +4 upper floors).
P.K.Mallick
munamallick@yahoo.co.in (munamallick@yahoo.co.in)
mallick.pravatkumar@gmail.com (mallick.pravatkumar@gmail.com)
vikram.jeet General Sponsor
Posted: Tue Feb 10, 2009 4:38 am Post subject: VERTICAL EXTENSION OF OLD BUILDING. |
CBRI Roorkee may be checked up for undertaking such studies
on old buildings and their foundations
vikramjeet
sdec.in Silver Sponsor
Posted: Tue Feb 10, 2009 6:25 am Post subject: VERTICAL EXTENSION OF OLD BUILDING. |
with Pile foundations, it's going to be very tricky,as it maybe difficult to examine the no and spacing and exact arrangement of piles. it's length below cut-off lvl, grade of concrete used and r/f provided in piles.
Let's hope it's isolated footings, otherwise the ptoblem at hand will become more complex and almost unmanageable(will need elaborate investigations by a Professional agencyand in fact the cost thus incurred maybe very steep).
Sangeeta Wij
Quote: | ----- Original Message -----
Sent: 09 February, 2009 6:52 PM
Mithilesh
sakumar79 wrote: Perhaps footings can be exposed at a few locations (only peripheral columns will be feasible) to estimate load capacity and a rough estimate can be made to check if load with the extra floor is within limits... If this is reasonable at a few locations, it may be proceeded with an extra floor...
Arun
