aapkamitrgss SEFI Member
Posted: Thu Jun 18, 2009 6:01 am Post subject: Teng's curve |
i was designing foundations for towers... i came across the name teng's curve. can anybody explain this and provide me the reference and where it has been used.
If a image of teng's curve or any literature i can get here, will be very helpful...
Thanks in advance.
Gurnam Singh
Thankful People |
sudeep_sharma(06-12, 10:31), Thanks aapkamitrgss for his/her post
fungineer ...
Posted: Thu Jun 18, 2009 6:11 am Post subject: |
Teng's Chart is used when the foundation is under tension (uplift in case of towers). In such cases, the effective area of the foundation is reduced and the pressure is recalculated.
Normal Case P/A+M/Z
Uplift Case P/A1+M/Z
Where A1 is the reduced area.
PNP
Posted: Thu Jun 18, 2009 6:45 am Post subject: |
is there any reference..
any image of the teng's curve may please be uploaded?
JVCSNL ...
Posted: Thu Jun 18, 2009 6:56 am Post subject: Teng's curve |
Dear Mr. Gurnam Singh,
Teng's curves are very popular in foundation engineering.
The reference is W C Teng's foundation design book. (Might be out of print). Other reading material is Hansen and Peck book.
Almost all the foundations are subjected to axial force and bending moments about both the axes. You may recall from the principles of direct and bending stresses that when the application of load is within the kern of the foundation, bearing pressure (P/A+/- Mi/Zi) below footing is compressive in nature.
However, when the load is outside kern, the bearing pressure in footing is not compressive within footing and there exists negative pressure at one or more corners.
Since, there is no medium between footing pad and soil to resist this tension (called uplift) the portion in negative area can not be considered effective. In this case, the entire load shall be taken by the portion of footing in contact with soil. Since, in all conditions, the equilibrium shall occur, the bearing pressures gets modified and location of neutral axis also shifts.
Though, this concept looks simple in nature, it is very difficult to obtain modified pressure values and location of neutral axis after satisfying equilibrium conditions.
Teng's chart provides the factor to calculate modified pressure based on the eccentricity of the loading point for rectangular footings. Teng's charts are divided in 4 zones and for each zone the factor and formulae to calculate modified pressure is given. It shall be noted that these charts are only for calculation of bearing pressure for rectangular footing. The stability checks needs to be applied as usual.
Jignesh Chokshi
Thanks in advance.
Gurnam Singh
jiwaji ...
Posted: Thu Jun 18, 2009 8:48 am Post subject: Teng's curve |
Dear Mr Choksi
I will be greatly obliged if you could mail me the Teng's full charts (4-zones) to my email id jydesai@tce.co.in
Jiwaji Y Desai
DGM (C&S)
TCE Jamshedpur
"JVCSNL" <forum@sefindia.org>
06/18/2009 12:47 PM Please respond to
general@sefindia.org
To
general@sefindia.org cc
Subject
[SEFI] Re: Teng's curve
Jignesh Chokshi
Thanks in advance.
Gurnam Singh
Quote: | ----------------------------------------------------------------------------------------------------------
Information transmitted by this E-MAIL is intended only for the use of the addressee(s) and contains
information that is privileged, confidential or exempt from disclosure under applicable law.
If you are not the intended recipient or it appears that this mail has been forwarded to you without
proper authority, you are notified that any use or dissemination and or copying of this email in any manner
is strictly prohibited and you are requested to delete this e-mail immediately. Communicating through e-mail
is not secure and capable of interception and delays.
Any one communicating with TCE Consulting Engineers Ltd., and / or its subsidiaries or associates
or group companies by e-mail accepts the risks involved and their consequences.
While this e-mail has been checked for all known viruses, the addressee should also scan for viruses
and notify the originator of e-mail.
Joined: 21 Feb 2008 Posts: 5552 Location: Gaithersburg, MD, U.S.A.
Posted: Thu Jun 18, 2009 3:12 pm Post subject: Teng's curve |
Dear Er Gurnam Singh,It may be available in the book Teng, W.C. (1962) Foundation Design, Prentice-Hall Inc., PHI had an Indian edition- which is available with me in India. Sorry I can not send you the chart, as I am now in USA.
But since you are doing the design of tower foundations, I suggest you to refer to my paper in ICJ:
1) Subramanian N., and Vasanthi, V., Design of Tower Foundations, The Indian Concrete Journal, Vol.64, No.3, March 1990, pp. 135-141
The following books also may be of help:
2)Varghese, P.C., Design of Reinforced Concrete Foundations, Prentice Hall Of India, 2005, See Chapter 19 on Tower Foundation3) Murthy, S.S. and Santhakumar, A.R., Transmission line structures, McGraw hill, Singapore, 1990.Best wishesSubramanian
Quote: |
Subject: [SEFI] Teng's curve
Date: Thursday, June 18, 2009, 11:31 AM
Thanks in advance.
Gurnam Singh
Last edited by Dr. N. Subramanian on Thu Oct 20, 2011 4:26 pm; edited 1 time in total |
lele_raj ...
Posted: Thu Jun 18, 2009 11:08 pm Post subject: Teng's curve |
Hi Gurnam,
I was in tower industry for quite a while, in India as well as overseas, but never heard of Teng's curves. If you have any foundation-specific question, pl. email it. I'll try to respond.
Best regards,
Rajendra (Raj) Lele
P Please consider the environment before printing this e-mail or any attachment/s.
Sent: Thursday, 18 June, 2009 4:01:06 PM
Thanks in advance.
Gurnam Singh
Access Yahoo!7 Mail on your mobile. Anytime. Anywhere. Show me how.
patole SEFI Member
Posted: Fri Jun 19, 2009 7:47 am Post subject: Teng's curve |
Friends,
Pl. see attached Teng's charts. These charts are use to calculate the contact area of foundation under vertical load + biaxial bending conditions. There is one chart with four graphs for four different conditions. Also this will provide you different formulas for calculating Maximum pressure under different conditions.
Pl. let me know if you need any further information on this
Vivek Patole
DCE
Chemtex India
On Fri, Jun 19, 2009 at 9:02 AM, drnsmani <forum@sefindia.org (forum@sefindia.org)> wrote:
[quote] Dear Er Gurnam Singh,It may be available in the book Teng, W.C. (1962) Foundation Design, Prentice-Hall Inc., PHI had an Indian edition- which is available with me in India. Sorry I can not send you the chart, as I am now in USA.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
2)Varghese, P.C.,Design of Reinforced Concrete Foundations, Prentice Hall Of India, 2005, See Chapter 19 on Tower Foundation3) Murthy, S.S. and Santhakumar, A.R., Transmission line structures, McGraw hill, Singapore, 1990.Best wishesSubramanian
Download |
Filename: |
tengs_chart.pdf |
317.04 KB |
Downloaded: |
4905 Time(s) |
Posted: Fri Jun 19, 2009 2:29 pm Post subject: Re: Teng's curve |
Dear Er Vivek,
Thanks for attaching Teng's chart. I think it will be useful in the case of footings subjected to ecc. loading or footings with AF and BM.
But it will not be useful for tower foundations. Hence Er. Gurnam should follow the references as listed out by me or the Manual on Transmission line Towers published by Central Board of Irrigation and Power, New Delhi-It is very old and I am not sure whether out of print.
As Er Rajendra Lele has said, I am also hearing about these Teng's curves for the first time and never used it.
[quote="patole"]Friends,
Vivek Patole
DCE
Chemtex India
Quote: | Dear Er Gurnam Singh,It may be available in the book Teng, W.C. (1962) Foundation Design, Prentice-Hall Inc., PHI had an Indian edition- which is available with me in India. Sorry I can not send you the chart, as I am now in USA.
vikram.jeet General Sponsor
Posted: Sat Jun 20, 2009 4:41 am Post subject: Teng's curve |
Kindly refer to the book'Fondation Design by Wyane C Teng
All related curves for design of foundations subjected to biaxial
moments and needing redistribution of base pressures
are given in that book
vikramjeet
