Teng's curve
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
JVCSNL
PostPosted: Tue Jun 30, 2009 3:21 am    Post subject: Re: Teng's curve Reply with quote
As requested by others, the generalized numerical approach to solve footings loaded with biaxial eccentricity is uploaded.
Jignesh Chokshi
Footing_With_BiAxial_Moments.pdf
Numerical approach for analysis of footings subjected to axial loads and large bi axial moments
 Filename:  Footing_With_BiAxial_Moments.pdf
 Filesize:  193.65 KB
 Downloaded:  35827 Time(s)
ishacon
PostPosted: Tue Jun 30, 2009 10:42 am    Post subject: Teng's curve Reply with quote
Well, back in 1969 at IIT Madras, Prof Shankaran introduced us in final year B.Tech ,to Teng's curves
from book Foundation Design by Teng !!!
VP AGARWAL
ISHA CONSULTANTS (P) LTD
NEW DELHI
PH : 011- 2630 1158
(M) 93 1345 2180
(M) 98 6826 2759
ishacon@bol.net.in (ishacon@bol.net.in)
ishacon.vpa@gmail.com (ishacon.vpa@gmail.com)
[quote] ----- Original Message -----
Sent: Sunday, June 28, 2009 7:23 PM
Subject: [SEFI] Re: Teng's curve
28th June 2009
I confess that I'm also unaware of Teng's curve.
In 1974-75, we had to design a sugar mill building - built up rigid portal frame, span 28.5 m., eaves height 15 m., with a 15 t. EOT crane. The foundations had a high eccentricity (M/P). We took recourse to the triangular positive pressure under the footing (considering the reduced base area) as proposed in 'Steel Designer's Manual' The building has performed satisfactorily over the years.
Indrajit Barua.
On Tue, 23 Jun 2009 drnsmani wrote :
prao5555
Progressive Member
Progressive Member
PostPosted: Wed Jul 01, 2009 8:08 pm    Post subject: Teng's curve Reply with quote
Date: Tuesday, June 30, 2009, 8:31 PM
Teng's curves
VP AGARWAL
NEW DELHI
PH : 011- 2630 1158
(M) 93 1345 2180
(M) 98 6826 2759
ishacon@bol.net.in
Sent: Sunday, June
28, 2009 7:23 PM
Subject: [SEFI] Re:
Teng's curve
28th June 2009
the years.
Indrajit Barua.
karthick.D
PostPosted: Wed Jul 08, 2009 7:06 am    Post subject: Teng's Curve Reply with quote
Dear ones
Can anybody help me in using Teng’s Curve . it is given that IV zones and corresponding formulas to find out the maximum pressure, but finding out the reduced area (Example: In case III how can we decide the distances N and M, is it by iteration or some other method) is tedious. I need more clarification on referring the chart and how to take values and interpret it with those formulas given for different zones. The informations will be very useful.
Karthick D
"This Message and its contents is intended solely for the addressee and is proprietary.Information in this mail is for L&T Business Usage only. Any Use to other than the addressee is misuse and infringement to Proprietorship of L&T ECC.If you are not the addressee please return the mail to the sender.L&T ECC DIVISION"
sudhakarebvn
PostPosted: Thu Apr 15, 2010 9:04 am    Post subject: Reply with quote
It is Very Simple, In Case -III from fig we acn find "D" value =0.5*L-el . Like wise A=0.5*B-eb. from these value we can find R value. Later on successive value can be found.
Good Luck
abhio
PostPosted: Thu Apr 15, 2010 12:00 pm    Post subject: Reply with quote
Dear Dr Subramanian, I could not understand why you say that the charts will not be useful for tower foundations. Could you please clarify?
Thanks and regards,
Abhijeet Oundhakar
sparkar
PostPosted: Fri Apr 16, 2010 8:16 am    Post subject: Reply with quote
Teng's Curve are widely used for design of open foundations subjected to axial loads in combination with biaxial bending. The curves are originally given in book " Foundation Design " by Wayne Teng. They have also been reproduced in the book " Concrete Bridge Design " by Dr. V.K. Raina.
bijay sarkar
PostPosted: Fri Apr 16, 2010 9:15 am    Post subject: Reply with quote
Teng's Chart is  used in case of detachment of foundation from soil. However, As the phenomena is complex in nature to idenfy what exactly happens, we do not allow such type of detachment of foundation for un-submerged condition check. For submerged condition check, 20% of the foundation area is allowed to be detached, if required.
Thanking you,
With regards,
Bijay Sarkar
bkkk
PostPosted: Fri Apr 16, 2010 12:51 pm    Post subject: Foundation design by Teng Reply with quote
Dear Sefians
Foundation design by Wayne C.Teng is a very usefull book on Siol Mechanics and foundation engg  and it is woth to buy the book at any cost.
er.Balaji venkateswaran
PostPosted: Fri Apr 16, 2010 6:56 pm    Post subject: Re: Foundation design by Teng Reply with quote
I think a cheap edition of this book is available in India
bkkk wrote:
Dear Sefians
Page 3 of 9
