blast load
kedarkhapare
PostPosted: Wed Nov 11, 2009 7:30 am    Post subject: blast load Reply with quote
Presently i am working on blast load analysis on building.So i need to know how to apply the blast load through time-history in Staad-pro.
scpatel_74
PostPosted: Fri Nov 13, 2009 3:29 am    Post subject: blast load Reply with quote
Kindly refer book on ‘Structural dynamics’ by J M Biggs…
Thanks and Regards
Sanjay Patel
Sent: Wednesday, November 11, 2009 1:01 PM
Subject: [SEFI] blast load
Yogesh.Pisal
PostPosted: Fri Nov 13, 2009 5:34 am    Post subject: Reply with quote
Dear Er Kedar,
It is not possible to apply time history for blast load on building in STAADpro.
Refer ASME Manual on Blast resistant design for chemical facilities.
Generally, force path for the blast load is as follows
1. Front wall will distribute the load to top slab and bottom slab / foundation
2. Top slab will resist the force transferred by front wall by rigid diaphragm action. Top slab will transfer this in plane force to the side wall.
3. Side wall will resist these forces by shear wall aciton.
4. Then it will be transferred to the foundation.
This force path is very difficult to simulate in STAADpro.
Non linear time history analysis for the blast load can be carried out manually (using EXCEL) by using simplified SDOF model for the walls and roofs (Refer Introduction to Structural Dynamics by Biggs)
If you want use the software, then you need to go for the advanced softwares like ANSYS.
Yogesh Pisal
revanwaghode
PostPosted: Fri Nov 13, 2009 1:51 pm    Post subject: blast load Reply with quote
Dear Kedar,
I have not applied blast loading.....but I guess we can take blast load equal to part of seismic load..
Seniors can guide you more on this.However I am attaching one article which i had download from collection of Er T. Rangarajan sir from SEFI only.It may help you in some way.
Abhay
On Fri, Nov 13, 2009 at 10:06 AM, scpatel_74 <forum@sefindia.org (forum@sefindia.org)> wrote:
Thanks and Regards
Sanjay Patel
From: kedarkhapare [mailto:forum@sefindia.org (forum@sefindia.org)]
BLAST_RESISTANT_DESIGN_OF_RC_STRUCTURES.pdf
 Filename:  BLAST_RESISTANT_DESIGN_OF_RC_STRUCTURES.pdf
 Filesize:  327.22 KB
 Downloaded:  1383 Time(s)
vicky43singh
PostPosted: Sun Feb 15, 2015 5:24 pm    Post subject: Re: blast load Reply with quote
Hey can you help me in blast loading topic???
Yogesh.Pisal
PostPosted: Mon Feb 16, 2015 4:08 am    Post subject: Reply with quote
Dear Er Vicky,
You can refer to ASCE Manual to Blast Resistant Design which is basic document in this area.
Best Regards,
Yogesh Pisal
Gokul_V
PostPosted: Wed Sep 25, 2019 9:41 am    Post subject: Blast Analysis Regarding Reply with quote
Anyone with the knowledge of Blast analysis Using ETABS and LS-DYNA please help with Legitimate, Understandable and Usefull References, as i'm Doing my M.Tech Master's Thesis on Blast Loading.
Thanks in Advance.
Gokul V.
kiranklk
PostPosted: Thu Sep 26, 2019 9:57 am    Post subject: Blast Load Analysis Reply with quote
We have done blast load analysis using ETABS. Blast load pressure calculated manually & ATBlast software. Blast Pressure is applied as pressure history function in ETABS & performed NTH analysis.
Blast load calculations are carried out as per the procedures outlined in section 5 of TM5 – 1300. The blast loads are distributed on all the structural elements on the front face as well as right face of the building. Following procedures and TM 5-1300 charts, software named ATBlast was developed by ARA (applied research associates) which calculates blast loads for given values of charge weights and standoff distances. This software calculates blast load dynamic parameters like shock front velocity, impulse, duration and time of arrival.
You can also refer:
Hand Book for Blast Resistance Design of Buildings
By Donald O Dusenberry
Link to our journal:
https://www.irjet.net/archives/V3/i8/IRJET-V3I8363.pdf
All the best.
 Filesize:  327.22 KB
 Downloaded:  88 Time(s)
Gokul_V
PostPosted: Thu Sep 26, 2019 12:30 pm    Post subject: Re: Blast Load Analysis Reply with quote
You can also refer:
All the best.
Dear Kiranklk,
Thank you for the Info. I have already studied your work using ATblast, it was very useful.
It would be very helpful if anyone can help me with LS-DYNA and regarding the software ATBLAST, is the software free or Can i get a student license ?
abhio
PostPosted: Tue Oct 01, 2019 10:12 am    Post subject: Reply with quote
Dear Er Pisal,
I had done blast loading in STAAD using time history of nodal forces. Perhaps this would be adequate?
