Time Period of the Structure
Goto page 1, 2, 3  Next
Arunbabu.S
PostPosted: Tue Mar 30, 2010 9:01 am    Post subject: Time Period of the Structure Reply with quote
Dear Sefians
I am analyzing a 33 storied building with dual system (Shear wall Framed Structure) in Etabs. In plan, the structure looks like an inverted T with base dimensions of about 40 m in X & Y. The height of the building is about 100 m. My queries are
<if>1. <endif>As my structure is with both Shear wall & Frame, As per IS 1893 which relation has to be followed to calculate Time period of the structure. [T=0.075h^0.75 (or) T=0.09h/Sqrt(D)]. At present I have taken an average of both the values considering my structure as partially infilled, is that correct.
<if>2. <endif>After analysis I have got the time period of about 6.8 seconds from Etabs. Is there any steps to reduce the Time period of my structure or any precautionary measures to be considered while designing the structural elements.
Arunbabu. S
"This Message and its contents is intended solely for the addressee and is proprietary.Information in this mail is for L&T Business Usage only. Any Use to other than the addressee is misuse and infringement to Proprietorship of L&T ECC.If you are not the addressee please return the mail to the sender.L&T ECC DIVISION"
akjhacpwd
PostPosted: Tue Mar 30, 2010 4:39 pm    Post subject: Time Period of the Structure Reply with quote
Dear Arun Babu
I feel it should be the second one because of presence of shear walls.
Secondly i am afraid the T shaped building in plan will face enormous torsion.
Best Wishes,
A K JHA
--- On Tue, 30/3/10, Arunbabu.S <forum@sefindia.org> wrote:
Subject: [SEFI] Time Period of the Structure
Date: Tuesday, 30 March, 2010, 8:53 PM
Dear Sefians
I am analyzing a 33 storied building with dual system (Shear wall – Framed Structure) in Etabs. In plan, the structure looks like an inverted T with base dimensions of about 40 m in X & Y. The height of the building is about 100 m. My queries are
1. As my structure is with both Shear wall & Frame, As per IS 1893 which relation has to be followed to calculate Time period of the structure. [T=0.075h^0.75 (or) T=0.09h/Sqrt(D)]. At present I have taken an average of both the values considering my structure as partially infilled, is that correct.
2. After analysis I have got the time period of about 6.8 seconds from Etabs. Is there any steps to reduce the Time period of my structure or any precautionary measures to be considered while designing the structural elements.
Arunbabu. S
The INTERNET now has a personality. YOURS! See your Yahoo! Homepage.
prof.arc
PostPosted: Wed Mar 31, 2010 12:25 am    Post subject: Time Period of the Structure Reply with quote
Dear Mr. Arun Babu,
Such a tall building of 33 stories should be treated as a special
structure and analysed carefully. The empirical values of period do
not cater to such special structures. The fundamental period of the
structure must be quite long - at the tail end
of the response spectra. You have not mentioned the country or its seismic zone.
The earthquake forces must be smaller than that of wind.
Also, design could be governed by the sway - P-delta effect and so on.
You should try different modelling and find out the variation.
Definitely, more than one person or agency must analyze it
independently to be sure that nothing is amiss.
I am glad that you got the oppurtunity to analyse a special structure
and wishing you the best..
Sincerely
Prof. A R Chandrasekaran
On 3/30/10, Arunbabu.S <forum@sefindia.org> wrote:
Dear Sefians
<![if !supportLists]>1. <![endif]>As my structure is with both Shear wall &
<![if !supportLists]>2. <![endif]>After analysis I have got the time period
Arunbabu. S
btgprasad
PostPosted: Wed Mar 31, 2010 6:57 am    Post subject: Reply with quote
If you consider slab elements as shell element, time periodwill be get reduced thus increases base shear. but ultimately reduce pt in swbecause sw will get stiff lateral supports at every levels. Program calculatedtime period dependent upon mass and stiffness so input decent pt in shear wallsin overwrite command before analysis(default 10mm dia@250mm).check if too many releases aregiven. try out with different combination/codes and study.
<o> </o>
I hope you considered following points in analysis
Proper load combination for p-delta,
live load reduction factors,
response spectra cases , ETABS scale factor for base shearcorrection in dynamic analysis,
gust
factor for windanalysis (H/B or H/L is less than 5),
avoid torsion mode in first few modes in considered numberof modes.
Overall stability checks, EQ with +_5% eccentricity, drift,slab diaphragm requirements .and lot.
<o> </o>
Remember very small issues in etabs sw-design beingrectified by developers so prefer strict manual check.
if you could send e2k file I can suggest some more .(mailbtg@gmail.com).
<o> </o>
Time period is all time issue for me.
sakumar79
PostPosted: Wed Mar 31, 2010 8:08 am    Post subject: Reply with quote
  If the building is T shaped, will it not make good sense to provide a seismic separation joint at the T interface and convert them into two rectangular structures? If not, you have to take into account the torsion generated due to earthquakes which can and will lead to much heavier reinforcement...
Arun
PostPosted: Wed Mar 31, 2010 2:26 pm    Post subject: Re: Time Period of the Structure Reply with quote
Dear Er Arunbabu,
As expressed by Prof. ARC, these formulae were derived for rectangular, regular buildings (FEMA 450 2001) and hence can not be applied to T-shaped buildings.
you may try the following UBC Formula:
T = 2π (Σwiδi2 /gΣfiδi)0.5
Where δi = Static elastic deflection at level i due to the forces fi
            fi = Lateral force at level i
            wi = gravity load at level i
            g = acceleration due to gravity
Best wishes and wishing you success in this project,
Arunbabu.S wrote:
Dear Sefians
Arunbabu. S
Arunbabu.S
PostPosted: Thu Apr 01, 2010 4:02 am    Post subject: Time Period of the Structure Reply with quote
Dear Sir
The Proposed Structure is located at Mumbai. I would like you to suggest some details regarding analysis for sequential loading, Creep & Temperature effects also.
Thank you for your suggestions and wishes.
Arunbabu.S
Sent: Wednesday, March 31, 2010 10:01 AM
Subject: [SEFI] Re: Time Period of the Structure
Dear Mr. Arun Babu,
Sincerely
On 3/30/10, Arunbabu.S wrote:
MANOJ MITTAL
PostPosted: Thu Apr 01, 2010 5:45 am    Post subject: Time Period of the Structure Reply with quote
T shape block can be split in to two rectangular blocks. It will improve its behaviour and may be cost effective as well .
MANOJ KUMAR MITTAL
BE,MSc,MS,CEng(I),MIE,FIAStructE,FIV
A-64, Sector-35, NOIDA-201307
09810039081 , 0120-2504381
manoj_shelter@yahoo.com (manoj_shelter@yahoo.com)
http://www.structures-india.com
Follow me on http://twitter.com/manoj_mittal
SHELTER CONSULTING ENGINEERS
*Structural Design & Retofitting * Construction Project Management * Green Buildings * Valuation *
This correspondence is from SHELTER Consulting Engineers and is intended
solely for the use of the recipient(s) named herein within the scope of
authorization, and may contain privileged, proprietary and/or confidential
information protected by laws and regulations. If you are not the intended
recipient(s) of this message, please notify the sender immediately, and
permanently delete the original, copies of it, any attachment and all
related printouts without reading or copying its contents.
This electronic message is not to be construed as contractual and/or legal
commitments by SHELTER Consulting Engineers,NOIDA.
--- On Wed, 31/3/10, akjhacpwd <forum@sefindia.org> wrote:
[quote]
Date: Wednesday, 31 March, 2010, 1:30 PM
Dear Arun Babu
Best Wishes,
A K JHA
--- On Tue, 30/3/10, Arunbabu.S wrote:
sarfaraj.husain
PostPosted: Thu Apr 01, 2010 6:00 am    Post subject: Time Period of the Structure Reply with quote
dear arun
your time pd. form etab is very high making structure very flexible.... please make your structure somewhat rigid to bring down the tp........as per 1893 your tp comes around 2.2 -2.4 secs......so you have to scale up the shear as per 1893 provisions....as building ht is around 100 m so serviceability may become one of the main criteria(making discomfort to persons living at upper stories) , so plan the frame size accordingly along with the other design criteria.
regards..
sarfraj
akjhacpwd to: general  03/31/10 10:49 AM
Please respond to general
Dear Arun Babu
Best Wishes,
A K JHA
akjhacpwd
PostPosted: Fri Apr 02, 2010 2:57 am    Post subject: Time Period of the Structure Reply with quote
That is what IS 4326 says.
Best Wishes,
A K JHA
Date: Thursday, 1 April, 2010, 11:36 AM
MANOJ KUMAR MITTAL
manoj_shelter@yahoo.com (manoj_shelter@yahoo.com (manoj_shelter@yahoo.com))
--- On Wed, 31/3/10, akjhacpwd wrote:
Dear Arun Babu
Best Wishes,
A K JHA
Your Mail works best with the New Yahoo Optimized IE8. Get it NOW!.
Page 1 of 3
