prof.arc ...
Posted: Thu Jan 06, 2011 12:28 am Post subject: RAFT Foundation |
If one does not model the foundation & soil but considers only the
superstructure over the foundation, then forces on foundation & soil,
could be worked out based on static check.
The external forces applied on the superstructure are ONLY vertical -
distributed over space for dead and live loads. This will result in
vertical reactive loads on the foundation & soil. The CG of applied
vertical loads will coincide with the CG of reactive loads.
A similar argument holds good for horizontal loads. The horizontal
loads applied at a height will result in horizontal reaction and as
upward & downward reactive forces due to moment caused by the lever
arm of horizontal force.
ARC
On 1/5/11, truenotesrakesh <forum@sefindia.org> wrote:
Quote: | Sir,
In Raft Foundation Design. We only consider vertical load from the column
and design. But what about the moment. I referred most of the books, non of
the book took moment.
with regards
RAKESH KUMAR |
rg.gupta ...
Posted: Thu Jan 06, 2011 6:05 pm Post subject: RAFT FOUNDATION |
DEAR ARC
YOU HAVE RIGHTLY SAID BUT IT IS VALID ONLY IF THE DESIGN IS DONE AS
RIGID FOUNDATION(CONVENTIONAL FOUNDATION) NOT AS FLEXIBLE FOUNDATION
DONE BY COMPUTER USING SUBGRADE REACTION OF SOIL.
CAN ANY BODY DESIGN THE FOUNDATION INCLUDING ISOLATED ,STRIP & RAFT AS RIGID BY THE USE OF COMPUTER ?
REGARDS
R.G.GUPPTA |
hemal ...
Posted: Fri Jan 07, 2011 6:20 am Post subject: RAFT Foundation |
Dear R.G.Gupta Sir,
Most of the structure design software treats ISOLATED FOOTING as rigid (uses SBC for design) and RAFT FOUNDATION as FLEXIBLE FOUNDATION (uses SOIL SUBGRADE REACTION for design).
Long ago, STAAD was having both (RIGID & FLEXIBLE i.e. SBC or Ks) options for RAFT FOUNDATIONS, but present versions only have FLEXIBLE option. Actually, as per my knowledge, design of RAFT foundation using RIGID method will be uneconomical (we can tell it conservative).
Hemal Mistry
--- On Thu, 6/1/11, rg_gupta <forum@sefindia.org> wrote:
Quote: |
Subject: [SEFI] Re: RAFT Foundation
Date: Thursday, 6 January, 2011, 12:05 PM
DEAR ARC
REGARDS
R.G.GUPPTA
VPandya General Sponsor
Posted: Fri Jan 07, 2011 10:54 am Post subject: |
Dear SEFIN'S,
May be I do not understand the question. Using modern day SOFTWARE'S like STAAD/PRO , RISA-3D and SAP-2000 there is no problem of doing AALYSIS and DESIGN of :
a) Flexible Raft Foundations.
b) Rigid Raft Foundation.
c) Applying Super-Structure Moments due to Lateral Load on Super Structure.
Recently I did 100ftX45ft X 3 ft thick Raft Foundation supporting 4 Liquid(Oil) and
Water containing Tanks. I use PLATE AND SHELL ELEMENT OF RISA-3D (Same in STAAD/PRO) to Model Concrete, Spring Element to Model Soil Springs (Winkler Springs). Applied Overturning Moments as Upward and Downward Forces at the nodes of junction between Tanks and Raft. You can nicely apply Loads in a Circular fashion for Circular Tanks.
Using real thickness of Concrete raft with PLATE AND SHELL ELEMENTS with Soil Spring Elements , Computer takes care if RAFT is FLEXIBLE or RIGID.
In these modern day software's like RISA-3D or STAAD/PRO Soil-Springs in Tension
due to Super Structure Overturning Moments are eliminated and loads are transfered to Compression-Springs only. There by giving correct SOIL-BEARING PRESSURE
due to Vertical Loads (DL + LL) and Overturning Moments (M).
This particular Raft I analysed and Design is already Built and Supporting those 4 tanks. This project is in HIGH SEISMIC ZONE. So there are large Overturning Moments. Remember in USA we have to submiit our Design and Drawings to Permitting Authority to get permit. They check our design. They acccepted my Foundation Design.
These Modern Day software's like RISA-3D and STAAD/PRO are varified by a large
users group and if properly used eliminate need for making lots of
old fashion assumptions like flexibility or Rigidty Raft, Soil Springs in tension.
ONE CHECK WE HAVE TO MAKE BY LONG HAND IS RESISTANCE OF LATERAL LOADS
AT FOUNDATION: This load (Lateral Shear) from super structure is resisted by
value of PASSIVE PRESSURE (Given by Soil Consultant) on THICKNESS OF RAFT
and FRICTION value between RAFT and, Soil also given by Soil Consultant.
Some times these two resistancences are not enough for high Lateral Shears. In that case provide DEEP GRADE BEAMS attached at the bottom of RAFT to develope
more Passive Resistance.
Regards.
Vasuddeo Pandya P.E. ; S.E. ; MASCE
Structural Engineer |
ibarua General Sponsor
Posted: Sun Jan 09, 2011 4:35 am Post subject: RAFT Foundation |
9th Jan 2011
Treating a raft foundation as rigid is not only wrong but is also dangerous.
The correct way to design rafts is to treat them as beams on an elastic foundation, by means of the following methods:
(i) Miklos Hetyeni's closed solution
(ii) Finite grid method (J.E. Bowles)
(iii) Finite element method.
Indrajit Barua.
On Fri, 07 Jan 2011 14:26:02 +0530 "hemal" wrote
[quote] Dear R.G.Gupta Sir,
Hemal Mistry
lele_raj ...
Posted: Sun Jan 09, 2011 10:37 am Post subject: RAFT Foundation |
I partially with Indrajit. Raft footing on soft, low BC soil is normally designed as beams on elastic foundation. But for hard, high BC soil, soil deformations are normally minimal and do not impact on the behavior of raft footing under load. In such a case, raft footing can be considered as "rigid". I've heard, but neither practised, nor read in the literature, of a raft footing on a hard rock strata being treated as an elastic plate.
Best regards,
Rajendra (Raj) Lele
Sent: Sun, 9 January, 2011 4:30:05 PM
9th Jan 2011
Indrajit Barua.
Hemal Mistry
--- On Thu, 6/1/11, rg_gupta wrote:
sarfaraj.husain ...
Posted: Mon Jan 10, 2011 6:41 am Post subject: RAFT Foundation |
i agree with Mr. Lele.....his explanation with technical term "do not impact on the behavior of raft footing" is almost perfect.....
sarfraj
lele_raj to: general 01/09/11 04:59 PM
Please respond to general
Best regards,
Rajendra (Raj) Lele
9th Jan 2011
Indrajit Barua.
On Fri, 07 Jan 2011 14:26:02 +0530 "hemal" wrote : Dear R.G.Gupta Sir,
Hemal Mistry
-- ญญ
Posted: Mon Jan 10, 2011 12:34 pm Post subject: RAFT Foundation |
10th Jan 2011
I've so far never come across the need for a raft foundation on hard rock.
Indrajit Barua.
On Sun, 09 Jan 2011 16:58:41 +0530 "lele_raj" wrote
Quote: | I partially with Indrajit. Raft footing on soft, low BC soil is normally designed as beams on elastic foundation. But for hard, high BC soil, soil deformations are normally minimal and do not impact on the behavior of raft footing under load. In such a case, raft footing can be considered as "rigid". I've heard, but neither practised, nor read in the literature, of a raft footing on a hard rock strata being treated as an elastic plate.
Best regards,
Rajendra (Raj) Lele
9th Jan 2011
Indrajit Barua.
Hemal Mistry
prof.arc ...
Posted: Tue Jan 11, 2011 12:12 am Post subject: RAFT Foundation |
A food for thought !!
Is a raft necessary on Hard Soil ?
I thought Raft / Piles are used when soil is iffy to support footings of columns
in that case, raft may have to be designed as a plate resting on flexible soil
ARC
On Sun, Jan 9, 2011 at 5:00 PM, lele_raj <forum@sefindia.org (forum@sefindia.org)> wrote:
Posted: Tue Jan 11, 2011 4:53 am Post subject: THICKNESS OF CONCRETE ELEMENT (RIGID) NOT SOIL |
RIGIDITY OF RAFT MEANS RIGIDTY OF CONCRETE ELEMENT and not the Hardness
or Softness of supporting Soil.
For same Vertical Loads (Dl + LL ) and OVERTURNING MOMENT (M) a Very Thick
Concrete (say 11 Ft.) will have no flexure stresses (Bending Moment) in Concrete
and a nominal thickness ( 3 ft.) willl bent like a beam bending and will have flexure
stresses in concrete.
Thick Concrete ( 11 ft.) will rotate like a Rigid Plate on Soil Springs with no flexure
Stresses. For Vertical Loads only Shear Stresses in Concrete no Flexure Stresses.
It is the Rigidity or Thickness of Concrete Element and not the stiffness of the Soil,
Soft Soil or Hard Soil is the issue in such analysis. If you have a Concrete footing
sitting on Rock Surface you will have only Direct Bearing Stresses and no flexure stresses.
Vasudeo Pandya
Structural Engineer. |
