DOUBLY REINFORCED BEAM IN STAAD
suresh_sharma
PostPosted: Fri Apr 01, 2011 2:59 am    Post subject: DOUBLY REINFORCED BEAM IN STAAD Reply with quote
Is there any command in Staad pro to direct the software to design the beam as doubly reinforced or it will be automatically done for the lower depth of beam.
sukanta.adhikari
PostPosted: Fri Apr 01, 2011 4:09 am    Post subject: Re: DOUBLY REINFORCED BEAM IN STAAD Reply with quote
Dear Mr Suresh,
STAAD will automatically switch on to doubly reinforced section(Once singly reinforced criteria is not satisfied) when designed by IS 456:2000.
S.Adhikari
amit_sharma
Progressive Member
Progressive Member
PostPosted: Fri Apr 01, 2011 4:36 pm    Post subject: Re: DOUBLY REINFORCED BEAM IN STAAD Reply with quote
Staad automatically takes the doubly reinforced beam. We need not to give any command for this.
nnsivakumar
PostPosted: Thu May 05, 2011 7:49 am    Post subject: Reply with quote
How to we know that a section is designed as doubly reinforced from STAAD results?
bkkk
PostPosted: Fri May 06, 2011 11:19 am    Post subject: Reply with quote
Dear sir,
We can find a beam double reinforced by means of  Ast in compression side of a section and by its depth for a given length of a beam.
Er.balaji venkateswaran
suresh_sharma
PostPosted: Sat May 07, 2011 4:32 pm    Post subject: Reply with quote
In my view it is not easy in STAAD PRO to find out whether the beam has been designed as singly reinforced or doubly reinforced. However it can be easily found out in RC Designer of Staad Pro, In the Main Rft Table for beam of R C Designer, there is a column namely As' req in mm2 which indicates the quantity of compression reinforcement in beam. The column contains zero value for singly reinforced section and some non zero value for doubly reinforced section of the beam.
prabhusaii
PostPosted: Mon Sep 26, 2011 6:41 pm    Post subject: L-COLUMN Reply with quote
DEAR SIR
  HOW TO CREATE L-COLUMN USING STAAD PRO MODEL PLZ GIVE SOME EXAMPLES
Swaran
PostPosted: Sun Nov 04, 2018 1:37 pm    Post subject: doubly reinforced beam in staad pro Reply with quote
Hello
When I designed in staad pro I got the Area of reinforcement in compression is greater than area of steel in tension. Is this possible?
 Filesize:  50.06 KB
 Viewed:  17 Time(s)
sakumar79
PostPosted: Sun Nov 04, 2018 4:22 pm    Post subject: Reply with quote
Dear Er Swaran,
     I dont think that is the case here looking at the steel provided and section properties. It is more likely that you have entered loads in +ve Y direction instead of -ve Y direction.
Hope that helps,
Arun
