Seismic Design
Goto page Previous  1, 2, 3, ... 42, 43, 44  Next
thirumalaichettiar
PostPosted: Sat Apr 02, 2011 2:19 am    Post subject: Reply with quote
Pl.find attached a PDF file on the following topic. It is an interesting article for those want to learn EQ.
A conceptual design approach to manage large earthquake forces
By Yusuf Ate Süleyman Demirel University, Isparta, Turkey.
From the above article it is evident that structures even with regular one analysed and designed using sophisticated software and with high degree of accuracy, detailed as per codes and with good construction practice will be of little use if the followings are present:
1. Wrong ORIENTATION.
2. WRONG CHOICE OF SHAPE.
T.RangaRajan
Ates.pdf
 Filename:  Ates.pdf
 Filesize:  2.98 MB
 Downloaded:  1502 Time(s)
Last edited by thirumalaichettiar on Sat Apr 02, 2011 10:43 am; edited 1 time in total
bipinsh
PostPosted: Sat Apr 02, 2011 8:08 am    Post subject: Reply with quote
thirumalaichettiar wrote:
Need Seniors and experienced engineers share their ideas for the following doubts?
7.When need to consider the Vertical force of EQ ?
8. Is Equivalent Static method consider the Vertical force of Earthquake?
9. Why moment redistribution is not considered in EQ analysis?
10.If a structure has long span or if the cantilever is more than 5m is worth to neglect the vertical force of EQ?
More to come.
T.RangaRajan
Thanks Mr Rangarajan Sir for raising such important and little controversial aspect on this forum. really eager to read some response on these matter from SEFI seniors. We can find lots of materials on horizontal Ground motions and response of the structures to such motions But hardly many talks about vertical ground motion. I am  presently living at a place close to the active faults and from experience of earthquake with near source in the  past, i fill we should include the vertical force into seismic design and structure should be designed for combined effect of horizontal and vertical EQ ground motion, but there is no consensus among the designer on this matter.
thirumalaichettiar
PostPosted: Sat Apr 02, 2011 9:05 am    Post subject: Reply with quote
SEISMIC STEPS:
Pl. find attached PPT of the above prepared by me along time back.
T.RangaRajan
36405231-Seismic-Design-Steps.ppt
 Filename:  36405231-Seismic-Design-Steps.ppt
 Filesize:  245 KB
 Downloaded:  1360 Time(s)
bipinsh
PostPosted: Sun Apr 03, 2011 9:58 am    Post subject: Reply with quote
I have worked a bit on the vertical ground motion effects on structures and collected some useful work carried out around the world on the response of engineering structure to vertical ground motion. Hope this will help in initiation of broader discussion on vertical ground motion.
Bipin Shrestha
vertical ground motion seminar paper.pdf
 Filename:  vertical ground motion seminar paper.pdf
 Filesize:  383 KB
 Downloaded:  1528 Time(s)
thirumalaichettiar
PostPosted: Sun Apr 03, 2011 4:11 pm    Post subject: Reply with quote
Dear Er.Bipin Shrestha,
Thanks for posting your research work and is a good enthusiastic one. I welcome like the above from more from more seniors and experienced engineers.
T.RangaRajan.
PostPosted: Mon Apr 04, 2011 8:08 am    Post subject: No Title Reply with quote
Dear Rangarajan sir,
As per personal opinion on questions :
The EQ coefficient in vertical direction = 2/3* Horizontal EQ coeff
Vertical EQ Force is co-existant with Horizontal EQ force
Also, this is +ve as well as -ve, i.e. It must be checked for both
additive and subtractive effects
Ideally speaking a structural member must be checked for this
coexistent force
However vertical EQ has critical effect on cantilevers , Transfer Girders
in buildings . In bridges ,it must be considered for bearings, pile cap, pier
and foundation design and cantilever construction.
Yes
Generally structure under Eq condition is designed for a much lower force
than actual EQ and stucture is safe against collapse through DUCTILITY
provisions as result of actal EQ on it during an EQ event
Structure under EQ event has already undergone all sorts of distribution and
redistribution of forces and somehow struggle to survive, thanks to ductile
nature of steel reinforcement provided at proper places under ductile detailing.
Therefore taking relief at structural sections by carrying any redistribution of
EQ moment is just like mirage(water availability delusion) in desert.
Codal stipulations ,too, do not permit it.
Rather it is suicidal to neglect vertical seismic.
best regds
vikramjeet
More to come.
thirumalaichettiar
PostPosted: Mon Apr 04, 2011 7:01 pm    Post subject: Reply with quote
Dear Er.vikram.jeet,
Thanks for your personal explanations to some of the questions but I need more in depth answers from other seniors.
I will be posting my reply soon.
T.RangaRajan.
Last edited by thirumalaichettiar on Mon Apr 04, 2011 10:52 pm; edited 1 time in total
thirumalaichettiar
PostPosted: Mon Apr 04, 2011 7:21 pm    Post subject: Reply with quote
Seismic Design of Precast concrete building structures.
As the file is about !3MB it could not be loaded and I will request admin to add it under this topic.
T.rangaRajan.
thirumalaichettiar
PostPosted: Mon Apr 04, 2011 11:14 pm    Post subject: Reply with quote
Time period:
Reference-page 33- earthquake Resistant Steel Structures -Acer Mittal
Attached in zip format.
T.RangarRajan.
Time period.zip
 Filename:  Time period.zip
 Filesize:  111.62 KB
 Downloaded:  1021 Time(s)
thirumalaichettiar
PostPosted: Mon Apr 04, 2011 11:17 pm    Post subject: Reply with quote
A book on EARTHQUAKE RESISTANT STEEL STRUCTURE AS PER EURO-CODE IN PDF FORMAT IS ATTACHED.
T.RangaRajan.
Earthquake_EN.pdf
 Filename:  Earthquake_EN.pdf
 Filesize:  2.72 MB
 Downloaded:  1350 Time(s)
Page 2 of 44
