Link For Spreadsheets
Hashmi
PostPosted: Mon May 30, 2011 9:54 am    Post subject: thanks Reply with quote
bipinsh wrote:
Wonderful work Indeed.
Thanks once again for your splendid work.
To,
B.V.Harsoda
Thank you for your Tremendous dedicated work....
Hashmi
PostPosted: Mon May 30, 2011 9:59 am    Post subject: Thanks Reply with quote
Thank you very much sir, for your tremendous efforts
venkatesh
PostPosted: Tue May 31, 2011 12:45 pm    Post subject: Reply with quote
some spread sheets even as per IS codes are available at http://theconstructor.org/others/civil-engineering-spreadsheets/337  which are freely downloadable.
Thanks & regards
Venkateshwar Rao
B.V.Harsoda
PostPosted: Tue May 31, 2011 2:12 pm    Post subject: Reply with quote
Thank you very much Dear Er. Venkateshwar Rao for useful link, Below are
direct links of spresdsheets for Download as you have already suggested in
your above post.
Here you will find spreadsheets related to civil engineering which will reduce
the work load of complicated and time consuming calculations.
Download the following spreadheets
1. Steel Design Spreadsheet
2. Friction Coefficient Calculator Spreadsheet
3. Earthquake Load Calculation Spreadsheet
4. Hydraulic Structure Design Spreadsheet
5. Beam Design Spreadsheet
6. BIS Code of Practice Spreadsheet
7. Volume of Concrete and Steel Calculation Spreadsheet
8. Deep Beam Design Spreadsheet
9. Earthquake Base Shear Spreadsheet
10. Flood Calculation Spreadsheet
11. Moment of Resistance Calculator Spreadsheet
12. Program for Installation of Precast Concrete
13. Rectangular Water Tank Design Spreadsheet
14. Section Property Calculator
15. STAAD Parameters
thirumalaichettiar
PostPosted: Wed Jun 01, 2011 12:21 am    Post subject: Reply with quote
Dear Er.Harsoda,
Really great to the spreadsheets but many f them are not for IS code and some are not working properly say the EQ load calculation.
Hope the above may be used as a guide.
T.RangaRajan.
fungineer
PostPosted: Thu Jun 02, 2011 10:28 am    Post subject: Link for spreadsheets Reply with quote
All,
You can find the above mentioned xl sheet in the website below.
http://www.engineering-international.com/
gautham_sathish
PostPosted: Thu Nov 22, 2012 1:37 pm    Post subject: Reply with quote
What is the password for spreadsheet 'concrete tunnel' ?
Most spreadsheets are locked and asks for a password to unlock..Sad
thirumalaichettiar
PostPosted: Thu Nov 22, 2012 3:19 pm    Post subject: Reply with quote
These xls sheets are password protected and you have to get it by payment.
T.RangaRajan.
naga
PostPosted: Sat Nov 24, 2012 6:31 am    Post subject: Re: Link For Spreadsheets Reply with quote
thanks for this post.I t is very usefull
B.V.Harsoda wrote:
Foundation Design Group
For Download click on Below Titles
1Free Standing WallFree Standing Masonry & Conctere Wall Design Based on TMS 402-08 & ACI 318-08
2Eccentric Footing
Eccentric Footing Design Based on ACI 318-08
3FlagpoleFlagpole Footing Design Based on Chapter 18 of IBC & CBC
4Masonry Retaining WallMasonry Retaining / Fence Wall Design Based on TMS 402-08 & ACI 318-08
5Concrete Retaining WallConcrete Retaining Wall Design Based on ACI 318-08
6Masonry-Concrete Retaining WallRetaining Wall Design, for Masonry Top & Concrete Bottom, Based on TMS 402-08 & ACI 318-08
7Concrete PierConcrete Pier (Isolated Deep Foundation) Design Based on ACI 318-08
8Concrete PileDrilled Cast-in-place Pile Design Based on ACI 318-08
9Pile CapsPile Cap Design for 4, 3, 2-Piles Pattern Based on ACI 318-08
10Pile Cap Balanced LoadsDetermination of Pile Cap Balanced Loads and Reactions
11Conventional Slab on GradeDesign of Conventional Slabs on Expansive & Compressible Soil Grade Based on ACI 360
12PT-Slab on GroundDesign of PT Slabs on Expansive & Compressible Soil Based on PTI 3rd Edition
13Basement Concrete WallBasement Concrete Wall Design Based on ACI 318-08
14Basement Masonry WallBasement Masonry Wall Design Based on TMS 402-08
15Basement ColumnBasement Column Supporting Lateral Resisting Frame Based on ACI 318-08
16MRF-Grade BeamGrade Beam Design for Moment Resisting Frame Based on ACI 318-05
17Brace Grade BeamGrade Beam Design for Brace Frame Based on ACI 318-08
18Grade BeamTwo Pads with Grade Beam Design Based on ACI 318-08 & AISC 360-05
19Circular FootingCircular Footing Design Based on ACI 318-08
20Combined FootingCombined Footing Design Based on ACI 318-08
21Boundary Spring GeneratorMat Boundary Spring Generator
22Deep FootingDeep Footing Design Based on ACI 318-08
23Footing at PipingDesign of Footing at Piping Based on ACI 318-08
24Irregular Footing Soil PressureSoil Pressure Determination for Irregular Footing
25PAD FootingPad Footing Design Based on ACI 318-08
26Plain Concrete FootingPlain Concrete Footing Design Based on ACI 318-08
27Restrained Retaining WallRestrained Retaining Masonry & Concrete Wall Design Based on TMS 402 & ACI 318
28Retaining Wall for DSA /OSHPDRetaining Wall Design Based on CBC 10 Chapter A
29Tank FootingTank Footing Design Based on ACI 318-08
30Temporary Footing for Rectangular TankTemporary Tank Footing Design Based on ACI 318-08
31Under Ground WellUnder Ground Well Design Based on ACI 350-06 & ACI 318-08
32Stud Bearing Wall FootingFooting Design for Stud Bearing Wall Based on IBC 09 / ACI 318-08
33Wall FootingFooting Design of Shear Wall Based on ACI 318-08
34Fixed Moment ConditionFixed Moment Condition Design Based on ACI 318-08
35Flood WayConcrete Floodway Design Based on ACI 350-06 & ACI 318-08
36Lateral Earth PressureLateral Earth Pressure of Rigid Wall Based on AASHTO 17th & 2009 IBC
37ShoringSheet Pile Wall Design Based on IBC 09 / CBC 10 / ACI 318-08
<A>
naga
PostPosted: Sat Nov 24, 2012 7:05 am    Post subject: Reply with quote
VERY GOOD DESIGNS.SOOO.....MANY THANKS TO POST IN FORUM
REGARDS
MALLESWARA RAO
Page 4 of 8
